Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 03-05-2011, 09:10 AM
PMOrthotics is on a distinguished road
Talking Machining Acetal/Delrin guides
hello all
we currently mill acetyl products with an axyz millenium as 3d shape by flipping the work piece etc. Using 2 flute carbide cutters of ball nose 10mm on raster 1.2mm step over. Max cut depth is around 25mm, but average across piece is around 16mm. The finish is good/excellent. The product is all similar but different sizes/surface geometry (slight variations).
Newbie question really...Should we be undertaking this work in one cut/pass or should multiple passes be used. We require reasonable turnaround but do not want to damage our kit? Any experienced guys on here cutting this all day every day to offer some guidance?
Any help or pointers appreciated!
Old 03-05-2011, 02:17 PM
DMF_TomB is on a distinguished road
cutting Acetal / Delrin
Acetal machines easy and usually gives a good finish.
only thing i can say is plastics are not as rigid as metal. i have made fixtures from plastic before only to find cutting forces can easily bend part out of position.
clamping plastics in a vise or a chuck it is easy to distort their unclamped shape or they are curled in vise and after machining part is not parallel and or straight / flat.
sometimes using smaller diameter cutters and less depth of cut and feed may take longer but produce a more accurate part.
how a plastic part is held can have a big influence on speed it can be machined.
Old 03-05-2011, 08:09 PM
Many thanks for your reply.
we took a look today at how our fixture could be bettered. Currently we are using a picture frame of aluminium (milled from sheet) with a 5mm lip all round internal diameter of 500mm. 12mm bolts * 4 hold the plastic from side through jig. The plastic (30mm) bows easily and visibly and when we turnover is not held by anything other than bolts. So as a result of your advise and then us taking a look, we are modifying the design to incorporate 8 clamps to hold against the lip from top instead. The sound when milling on occasion would be wrong, although the parts were of a fine tolerance as they are low tolerance. Placing straight onto the vac bed gives a better result that we can hopefully imitate with the modified fixture.
As for the cut depths are these acceptable if the finish is fine or are there rules to follow that i am unaware of? The chips are fine, although i want to gain the optimum cutter life without destroying productivity?
Thanks for the suggestion, as i say very helpful.
[IMG] code is Off
Suitability of Acetal (Delrin) for Anti-Backlash Nuts Thomas Utley Linear and Rotary Motion 14 01-15-2011 10:26 AM
Delrin/Acetal Guides for an X2 n1bpd Benchtop Machines 5 08-31-2009 08:03 PM
Is this Delrin/Acetal? HackMax Benchtop Machines 4 06-20-2009 07:29 PM
Looking for 24" of Acetal/Delrin (or drops) - Suggestions? scorpion Glass, Plastic and Stone 1 02-25-2009 03:58 PM
deburring acetal/delrin acidcustom Mass finishing equipment/media/stratigies 3 03-25-2007 07:26 PM
