bump
Here is my problem:
I'm trying to engrave glass plate with my cnc router. I have a dremel 35,000 rpm and dremel engraving bit. When I start out the first letter--1.5 inch high, parkavenue font--turns out great. However, by the second letter the bit is "scratching the glass" not "frosting it".
Some things I tried:
1. Changed Z axis.
2. Tried different bits--dremel brand engraving.
3. Changed feed rate up and down.
Any hints or tips would be greatly appreaciated.
Matt
Try using some water or some other coolant?
If you Google 'cnc glass engraving' this is one of the links you will get.
http://www.2linc.com/glass_engraving.htm
I have been doing some searching for info on glass engraving and based on what I have found so far I think your Dremel engraving bits are not up to it; are they diamond tip?
Personally I'd use diamond, or corundum based stone.
I haven't done any engraving yet (heck, I don't even have a machine yet!) but I know there's a difference between diamond coated and diamond impregnated bits. When the coating on diamond coated bits wear down, the bit is pretty much toast. On the other hand, diamond impregnated bits last much longer (and cost much more) because as the material breaks down, fresh diamonds are revealed.
Do they make impregnated 'engraving' bits?
Carlo
Matt:
Question:
Is your work surface Parallel to the Dremel Tool? It will have to be Parallel to less than .001 inch to perform the task. Otherwise the cutter will not be able to engrave and will just scratch the surface.
Jerry
I have done some engraving on glass. I made my own springloaded tool holder. the problem is the rpm's are to high you need to be turning around 2000-5000 for glass then the cheaper bits will last a lot longer.
I've been in the glass industry for the past seven years and in my spare time I mess around with the cnc engraving and so on, I don't actually have an engraving bit but I use a diamond embedded router which works well always with water for coolant otherwise it just burns with the heat, and an even surface is crucial. unfortunately I don't have any pics from the work by the router, but I do have some pics of some brilliant cutting I've done and so on.
.....http://weekendoutdoors.awardspace.co...20waterjet.htm
I also have a site where I post free creative dxf files
.....http://flashanims.awardspace.com/
I don't charge for these files but if you want to earn me some beer money ha ha
you can click on an ad or two they are relative adds so they lead to interesting sites. also being as this is a hobby for me if anyone has a request I'm usually happy to draw up a dxf file in my spare time and post it.
this could be a problem of flatness of the table, if is not flat it will never be able to carve in the glass the way it should, take a big diameter tool a thick sheet of plexiglass and do an area clearance so it will make your table flat and then you should not have any problems the tool should do the job perfect
