Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-07-2011, 06:12 PM
hackmeister is on a distinguished road
turning boring uhmw
I recently did a job where I had to turn, drill , bore, and part off some rollers that were made out of uhmw. The uhmw was white (if it makes any difference)and it was a solid 3in. dia. bar. Anyway, I had a problem with the parts growing in size after they were out of the machine. I would check the bore dia. while it was in the machine and it would be right (1.848 dia.), but as soon as it was parted off it expanded about .003 Now here is where it gets weird. The parts would continue to expand about another .007 over the course of several hours.
I made sure all the tools were sharp, and I used the coolant on each operation. The chuck pressure was at 150 lbs.
Any guesses about why the parts got bigger?
Thanks so much.
Old 01-07-2011, 10:52 PM
tony978's Avatar
tony978 is on a distinguished road
I work at a place that did a long run with parts made out of that stuff and I wouldn't try making any thing but a paper weight out of that stuff .
i want to say if you don't encase it , it will move to ware ever it wants even years later . I hope this helps , I would rework it out of omething that is knowen not to move if your looking to hold any tolerence .
Old 07-21-2011, 07:43 PM
BOATDUDEGUY's Avatar
BOATDUDEGUY is on a distinguished road
IM CURRENTLY IN A PLASTICS SHOP AND DO PART OFF WORK
PARTS FURTHER AWAY FROM JAWS ARE FINE, AS YOU MOVE IN TOWARDS THE PRESSURE OF THE JAWS AFTER YOU CUT OFF THEY EXPAND DUE TO THE RELEIF OF NOT BEING GRIPPED, AND WE USE MANUAL CHUCKS, WE DO ALOT OF GLASS, MOLY,191, CARBON,GRAPHIT,PEK, DELRIN,UHMW,POLYPRO
ALL OF THE STUFF CLOSE TO THE CHUCK STRESS RELEIVES AFTER THE CUT, DELRIN WILL SHRINK, AND THERES STILL ALOT I HAVE YET TO DISCOVER
HOPE I HELPED
Old 07-21-2011, 07:45 PM
Thanks so much.
CHUCK PRESSURES TOO HIGH, IF AT ALL POSSIBLE EXTEND IT AS FAR AWAY FROM THE FACE OF THE JAWS AS YOU CAN AFTER CUTTING OFF IT STRESS RELIEVES
WE USE MANUAL CHUCKS, TIGHTEN BY HAND AND THE STUFF STILL BLOWS UP WHEN ITS CLOSE TO THE CHUCK!AND WE DONT COME NEAR TO 150LBS OF PRESSURE
Old 07-29-2011, 05:39 PM
Thanks BDG. I was wondering if the problem was related to the chuck squishing the stock. I havent had to run that job again yet ,but if I do I'll remember your advice.
Old 07-29-2011, 07:51 PM
its funny cuz if we have a part that needs to get passed and is out of tolerance we will sit it outside in the sun if we need it bigger or sit it in the frige to get it smaller however we need to get it passed, cuz when it shipps in ups the temp gets way hotter than the ac shop
plastic is a different animal
i never had to use diamond coated inserts before i came to this shop
191 carbon with some graphite when its cutting it dosnt look or sound like a big deal but regular carbide inserts will just get sanded down before we fininsh one peice of material!
MI LIKEY FISHI
[IMG] code is Off
Indexable boring bar in boring head? Molochnik General Metalwork Discussion 8 04-15-2010 07:36 AM
D'Andrea boring head, Solid Carbide boring bars etc. morehelium EBAY ADS 1 08-24-2009 11:19 AM
Boring and Turning with the same tool? Donkey Hotey Haas Lathes 14 12-13-2007 08:45 AM
Turning Boring and Drilling Nitralloy 135 ricotututi General Material Machining Solutions 3 11-06-2007 08:02 AM
turning-and-boring lathe 1563 promsnab CNCzone Club House 0 10-24-2005 09:40 AM
