Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 12-06-2010, 01:34 PM
Ferny's Avatar
Ferny is on a distinguished road
Help with ABS routing
Hi Guy's, I have a ABS routing job coming up. I need to cut about an inch deep pocket about 3"x4" with a couple features in it.
In the past I have not had much luck with. From what I have read it looks like HSS single or double fluted cutters with fast feed rate? Anyone have any other tips for me?
Thanks,
Ferny.
Old 12-07-2010, 11:08 AM
Frantic Fab's Avatar
Frantic Fab is on a distinguished road
abs likes to gum up at high speeds with typical end mill style cutters. plastics, in my experience, behave much better when cut with router bits. single or double flute, straight.
the other key component would be getting your chipload set correctly! with the two dialed in you can produce parts with no melting, gumming, fogging, nothing!!
Old 12-08-2010, 02:18 PM
Ferny's Avatar
Thanks!
Thanks Mister!
I made a few test cuts today at 20, 30, and 40 IPM and they all worked.
The swarf from the faster cuts shot off much better.
I'm at the lowest spindle speed of 5000 RPM? with a 1/4" carbide double helix bit. I also have a couple air streams directed at the bit.
I just need to work on the plunge speed to keep from birds nesting.
In the mean time the project manager decided he wants to change the part design...again.
Thanks again!
Ferny.
Old 12-09-2010, 12:52 PM
HA! managers.... well i am glad that helped. for the plunge try stepping down gradually. enter the material about .125 and back out then another .125 and so on. this will allow the material to be spat out avoiding the giant birdnest upon entry!
the air streams are a huge bonus! if you need a really clean finish you can mist the bit with air and soapy water! works sonders for acrylic and polycarbonate!
Anytime!
Garrett
[IMG] code is Off
Need A Quote- cnc routing adivito Employment Opportunity 2 12-05-2010 07:19 AM
Routing MDF on CNC Making chips Wood Working Tooling 11 12-11-2009 06:37 AM
RFQ 8' x 4' MDF routing igordon99 Employment Opportunity 0 11-19-2009 12:59 PM
Help Routing MDF? lgroulx200 DIY-CNC Router Table Machines 7 09-17-2008 07:09 PM
Q on CNC PCB Routing soundmotor DIY-CNC Router Table Machines 7 04-27-2006 06:16 AM
