Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 12-01-2010, 06:57 AM
CTOPS is on a distinguished road
Clear plastic sheet Recommendations
Does anyone have a recommendation for what type of clear plastic sheet material would be best for some sign boards I'm working on? These pieces average 36" X 60" with up to 300 5mm dia holes drilled in them.
The prototypes I've made have been fabricated using 1/8" plexiglass from one of the big box home improvement stores but the durability just isn't there. Too much spider cracking around the holes over time due to flexing of the material.
Any suggestions for material type and/or suppliers would be appreciated
Thanks!!
Old 12-01-2010, 07:27 AM
trevis1st is on a distinguished road
Are the holes where the spider cracking a mounting point? If so then is there a bushing of some sort to allow the acrylic not to bind? For something that size I would go with 1/4 or thicker material. Does the sheet need to be translucent or completely clear?
Old 12-01-2010, 07:39 AM
The design requires the use of clear material. The sheet floats within a grooved framework so there is no load from mounting screws etc.
The holes are for a plastic hangar bracket that is used to display sample chips. The hangar utilizes two holes spaced 1" apart and is unfortunatley designed for 1/8" thick material
Old 12-01-2010, 07:53 AM
How is it cleaned? I'm guessing the sample chips aren't very heavy. And the hanger bracket is fused or glued in place. Also how is it being fabricated? Flame polishing, lubrication? I had a customer come in with a 3/8 piece that had spider cracked around a hole. Turns out the lubricant he added was eating the acrylic. Cast acrylic would be more stable also. Sorry for the 20 questions
Old 12-01-2010, 08:07 AM
Thanks for your help!!
The piece is fabricated on our cnc router. The holes are peck drilled using an Onsrud drill designed for plastic (6000 RPM @ 50 IPM). No coolant or mist is being used during fabrication.
As for cleaning, we are using windex type cleaners to wipe off any dust. The hangar itself utilizes a pin and hook arrangement on the backside that clips into the two 1" spaced holes. No glue or adhesive is used for mounting. The front side has a 1-1/2" long X 1/8" dia rod that projects out for printed sample color chips to hang from
Old 12-01-2010, 08:43 AM
The Windex type cleaners can cause the spider cracking. Mild hand dish washing detergent and water is usually the best thing to use. Also a microfiber cloth. Another cleaning idea might be a lent roller. I use sign transfer tape to clean off dirt and dust from acrylics and polycarbonates.
Old 12-04-2010, 07:11 AM
Gold Member
RomanLini is on a distinguished road
I second that not using Windex or any window cleaner on acrylic! In most cases water and a soft paper towel works well, or the tinyest drop of detergent.
Another thing to try would be flame sealing the holes, as the drilling leaves microcracks in the material that will worsen over time and flexing. (Check with a micrscope).
Cyanoacrylic glue (like super-glue, crazy-glue etc) also do a good job of sealing the microcracks and you can paint that on before the product goes into use.
You could also get some cheap rubber or silicone grommets that will press in to the 1/8" acrylic and support the holes, reduce load, and even cover up cracks a bit once they start.
Old 12-04-2010, 04:53 PM
RSTYLR is on a distinguished road
Thumbs up RSTYLR
Consider using polycarbonate or on of the new poly/acyrlic hybrids (sorry, can't remember the name). We buy from AIN & use the hybrids for store fixtures, brochyure holders & displays with good success.
Old 12-04-2010, 07:52 PM
Flateric is on a distinguished road
If you choose to flame polish/seal the holes try to allow the plastic to cool as slowly as possible. This will help greatly in resisting crazing (spider cracks). Cooling can be slowed by placing a non-synthetic (so it will not melt itself of course) type of cloth over the heated part immediately after heat.
Being sure to use the sharpest tools available to you generally help in most milling situations or machining of any kind also seems to lead to less crazing.
[IMG] code is Off
Need A Quote- Small quantity Acrylic/Clear Plastic Sheets with Simple Cuts Johnnybgood3 Employment Opportunity 6 09-04-2010 04:45 PM
Newbie- Cutting Sheet Plastic swamper8 Laser Engraving & Cutting Machines 5 07-19-2009 07:19 PM
what material for molding clear plastic? mc-motorsports Moldmaking 22 06-29-2009 09:54 AM
Newbie- Optically Clear Plastic Material Recommendation lclore Glass, Plastic and Stone 2 10-07-2008 04:22 AM
Plastic sheet work Zamm Employment Opportunity 5 06-26-2007 08:34 AM
