Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 11-03-2010, 01:34 PM
GAGRO is on a distinguished road
Wire saw machine
I'm looking for machine who could cut irregular stone, irregular stone surface, I attached some images to show You what kind of lines should be cut. As you can se lines are not straight, they are irregular. Table size would be around 500mm x 500mm. So i was thinking that the best machine for this would be some wire saw machine, am i right?? If i'm not, which is the best? And where i can find it on internet to buy????
ID:	118316   Click image for larger version
ID:	118317   Click image for larger version
Old 11-03-2010, 06:01 PM
packrat is on a distinguished road
How about some thing like this; Diamond Saw Acessories
Google, diamond band saw , For more.
cary
Old 11-07-2010, 04:45 AM
I'm also find this when I start to search for some machines, but I wasn't sure this machine could cut very smal iregular lines of stone??? What You think? I can't find thinckess of this ring saw, i need thinckess from 1-5 mm.
Old 11-07-2010, 05:39 PM
Your best bet is to E-mail the company and ask them.
cary
Old 11-20-2010, 05:17 PM
joumpy is on a distinguished road
How about using a CNC milling machine with a diamond tool of small diameter?
Say Ø2 mm for example.
Tags
cnc cutting, wire saw
[IMG] code is Off
Need Help!- Help with 4 axis for FX10 wire Machine smilowski Mastercam 4 10-20-2010 07:39 AM
Edgefinding with wire machine ErnieD EDM Machines 2 03-09-2010 11:35 AM
New Sodick Wire EDM Machine (Affordability) AppliedMachine Product Announcements & Manufacturer News 0 01-11-2009 09:14 AM
4 conductor wire for my CNC Machine MagTDK DIY-CNC Router Table Machines 15 08-10-2006 01:19 PM
wire guide/track for cnc machine... SatanKlawz Mechanical Calculations/Engineering Design 9 05-28-2006 10:55 AM
