Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-05-2010, 10:30 AM
gpraceman is on a distinguished road
Drilling Acrylic
I a bit of a noob and am trying to drill holes in a stack of 0.093" acrylic. With my manual mill, I find that once the tip of the drill bit is down into the acrylic fully, that I can speed up the feed rate. So, my question is how can I replicate that in GCode for my CNC mill? I've tried peck drilling, but that seems to waste a bunch of time. I just want to start slow and then pickup speed once I get to a certain depth.
Old 10-05-2010, 10:40 AM
underthetire is on a distinguished road
Tap plastics sells a plastic drill. Has the cutting edge of the drill ground flatter. Makes a big difference. Does your CNC have a deep hole cycle? Those can be modified sometimes, or you will need to write a macro with the feed rate changes.
Old 10-05-2010, 10:49 AM
I'm using drill bits designed for drilling acrylic. My CNC machine is a small bench top unit (Zenbot) that I use Mach 3 to control.
[IMG] code is Off
Drilling Acrylic gpraceman Glass, Plastic and Stone 2 07-26-2010 11:56 AM
Acrylic: Drilling Holes and Newbie Questions about Feed formulas roamingdrone Glass, Plastic and Stone 2 09-22-2009 03:15 PM
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
drilling through 1" acrylic rod over 8"lenth jstwinbaby General Material Machining Solutions 3 12-08-2007 01:12 AM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
