Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 09-16-2010, 09:40 AM
liat is on a distinguished road
Is it possible thie element to be produced whit CNC router machine from plastic ?
Greetings to all of you.
Since I need to make just few elements like this and plastic injection molding will be very expensive is it possible this shape to be produced whit CNC?
Thanks in advance,
ID:	114693   Click image for larger version
Old 09-16-2010, 02:32 PM
awerby is on a distinguished road
Sure, it's possible.
You need a 3d CAM program (like DeskProto) and some ball-nose endmills. If you use DeskProto, try the 2-side wizard. It won't be particularly economical to mill them out individually, if you're selling them, but as a prototype it should work fine. You could also make a 2-piece silicone rubber mold and cast them in urethane, if you want to do a limited production run.
Andrew Werby
www.computersculpture.com
Old 09-16-2010, 03:13 PM
mcphill is on a distinguished road
Yes, that could absolutely be produced on a 3D mill/router. Another option would be rapid prototyping.
Old 09-17-2010, 05:43 AM
Thanks you really for the info.
Casting is not an options in this case I need many kind of different objects similar to this on the picture but 1 - 5 pieces max. Probably the best options is rapid prototyping. I found this printer: http://www.printin3d.com/3d-printers...nal-3d-printer at a reasonable price which probably will do the work.
Old 09-17-2010, 07:48 AM
You do need to be aware of the limitations of the printer, and the resolution you get. I have no idea what you are wanting the parts for, but the printer will leave ridges on the the surface. I suggest you use a service to have a few parts made on the machine you plan to purchase to insure that the surface finish is sufficient to meet your needs. You can get rapid prototyping machines from $8000 to over $300000, and there is obviously a difference in the output of the different machines. Again, the low end machine may well meet your needs, but only you can answer that question!
[IMG] code is Off
Router for Plastic Disks whiskey oscar Want To Buy...Need help! 5 10-06-2010 12:15 AM
Quote Awarded I have 2 aluminum assemblies I need produced Tri-J Employment Opportunity 9 07-20-2010 01:20 AM
Need Help!- Choosing CNC Router for Plastic Fab JohnClayton Want To Buy...Need help! 0 03-13-2010 05:40 AM
Interesting code is being produced. MrWild Dolphin CADCAM 3 03-03-2008 11:46 AM
mass produced skeetboy25 I.C. Engines 4 08-11-2003 07:47 PM
