Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 08-26-2010, 01:32 PM
NevNavi is on a distinguished road
help with the colibri 200 SW
Hello
I have a colibri200 machine, the machine works perfectly my trouble is with the programming SW
I changed my old computer because it doesn´t work any longer (motherboard failed), so i installed the new SW and the key drivers to the new computer, but when i try to save a file or generate an object file for the CNC i have an error message sayong that the key is missing (the key is installed and configurated)
software
ColibriCAM 4.65
easycad 3.06
colibritools 4.68
inoutCNC 1.5
SO: WinXP SP2
Thanx
Old 01-23-2012, 05:00 PM
Coonen is on a distinguished road
Originally Posted by NevNavi View Post
Hello
software
ColibriCAM 4.65
easycad 3.06
colibritools 4.68
inoutCNC 1.5
SO: WinXP SP2
Thanx
Hi
Do you have still this problem ore is this already solve?
You need to install Sentinel Keys (Sentinel Drivers| SafeNet) and a new Easycad version.
Regards Roy
[IMG] code is Off
