Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 07-29-2010, 12:40 AM
gtoshihiko is on a distinguished road
Routing PP Sheet
Hello,
I've recently been tasked with cutting polypropylene sheet on a CNC router. I'm using a 3/8" 2-flute upcut spiral at 16000 RPM and 300 IPM. The problem I'm having is in 3/4" thick material where I'm taking 1/4" passes and the chips are getting stuck in the groove left behind the tool path. This only happens on the 2nd and 3rd passes. When I say stuck I mean really stuck. High pressure air sometimes does not work to eject the chips. The stuck chips are being re-cut by the tool and causing a poor finish. I cut 3/4" thick polyethylene and even 1/2" thick polypropylene without this issue. Any advice is appreciated. Thanks in advance.
Old 08-01-2010, 01:06 AM
Moderator
ckelloug is on a distinguished road
Compressed air to blow the chips out and cool the tool would be my first guess. My second would be that your spindle speed is too high. I haven't ever done this task myself however so hopefully someone with more experience will comment.
Old 08-01-2010, 06:37 AM
ger21's Avatar
Cut your spindle speed to 10,000 - 12,000, or increase your feedrate.
[IMG] code is Off
CNC Routing? slamman WoodWorking 10 05-11-2010 12:55 PM
Routing 1/32 thick sheet metal dbtoutfit DIY-CNC Router Table Machines 0 08-09-2007 02:10 AM
RFG - FOAM SHEET ROUTING in MELB AUSTRALIA clp Employment Opportunity 1 10-26-2006 11:33 AM
Routing Alu sheet ScuD DIY-CNC Router Table Machines 9 09-26-2005 07:17 AM
Routing Aluminium sheet kong DIY-CNC Router Table Machines 11 06-10-2003 12:51 PM
