| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
Hello, I am building a machine and need help in deciding the right kind of cutter to use to cut: Material: Plastic sheet Thickness: 0.8mm Shapes: Rectangle, Square, Circular. Level of Accuracy: Microns Kindly specify the details of the cutter (blade, spindle or anything that you feel is right) along with the make details and from where I could get it. Thanks a ton! |
| Onsrud 63-515 1/8" O-flute. I run 13,000 RPM at 120 ipm feedrate with 0.06" depth per pass. This is a router bit and is available at a lot of places, I bought mine through Amazon. This bit should work with most plastics. The price will be mid $30.
__________________ Regards, Carl |
| I need to cut profile from 100mm thick HDPE sheet. My accuracy is +/-0.1mm. I only can locate Dia.1/2" x 1.5"cutting length, 2 straight flute router bit. It's the longest that I can find. So I'll just have to flop the sheet over to cut from the other side for a total 100mm (~4") thick sheet. My questions are What spindle speed & feed rate should I be using? Must I use compress air to cool the bit & clear the chips? Thanks in advance. Ken |
| Tags |
| cutting a plastic sheet |
| What type of end mill is used for plastic? | replicapro | General Metalwork Discussion | 10 | 07-21-2010 10:29 AM |
| I am new to this field. I want to know about cutter compensation type for Lathe? | manish2912 | Mastercam | 0 | 12-31-2009 09:59 PM |
| spindle motor and spindle control dont work | customcncparts | Milltronics | 0 | 10-01-2009 02:08 PM |
| Need Help!- Trying to find a specific type of cutter | Airassault | Want To Buy...Need help! | 4 | 03-20-2009 04:16 PM |
| Need Suggestions: Which type Plastic should I use? | KevinWilkins | Moldmaking | 25 | 08-23-2008 04:00 AM |
