| Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here. |
been working with very thick gray pvc lately. i'm having a hell of a hard time finding drills/feeds/speeds that are any good in this stuff. it mills incredibly easily and for the most part drills fairly easily too, except during deep hole drilling(anything deeper than an inch or so). the drills just gum up and end up splitting the part. i've played around with feeds and speeds but i'm not having much luck. so far it seems like the drills i should be using are highly polished, with a fairly sharp point. any ideas? |
__________________ Keith |
| . I would suggest a drill with a larger helix angle to increase the effective rake angle. This require less cutting force and thus less heat generated. Also a sharper point angle will help along with higher feedrate. Inconjuction with this an increased lip relief angle will help with the higher feed rate. Lightly buffing the cutting edges will help produce a sharper edge. Spray the drill with PTFE spray and use an air blast instead of coolant. Worth a try ![]() Brian
__________________ www.eBolt.co.uk http://stores.ebay.co.uk/ToolsAndBolts |
| Gray toolbar ??? | MachineManiac | CamWorks | 4 | 04-28-2012 08:08 AM |
| New Machine Build- 3/4" dark gray machinablePVC sheeting for a build? | coloradonewbie | DIY-CNC Router Table Machines | 11 | 11-28-2009 10:29 PM |
| Permanent Molds for Gray Iron? | maquiza | Casting Metals | 1 | 04-27-2006 04:19 AM |
| Tool Gray or White? | MrRage | General Metal Working Machines | 20 | 02-20-2006 11:01 PM |
| CNC Mill and CNC Lathe offered. Aluminum and Gray Iron Castings | maquiza | Employment Opportunity | 0 | 12-31-2005 10:37 AM |
