Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 06-18-2010, 10:24 AM
gpraceman is on a distinguished road
Drilling Acrylic
I'm drilling holes in some 0.093" thick acrylic and wondering just how many layers that I can stack to make the work go faster? I've been doing 5 at a time now problem, just wondering if there was some rule of thumb on maximum thickness. The hole sizes are from 1/8" to 1/4".
Old 07-19-2010, 09:37 AM
cpcp is on a distinguished road
No "rules" that I know of. The only thing I watch depends on on the cleanliness you require of the hole walls. The deeper the stack the more you tend to get a hot bit combined with molten acrylic; this can have the dual effect of giving rough wall finishes and injecting molten acrylic between the sheets causing them to bond or have raised surfaces about the hole.
As usual specific blade angles and 'pecking' helps significantly.
Old 07-26-2010, 11:56 AM
Wall finish isn't an issue. These are just screw holes. I am using drill bits specific to plastics. I have done some testing with peck drilling and that looks to be working out. I'll probably stick with 5 pieces high for now.
[IMG] code is Off
Acrylic: Drilling Holes and Newbie Questions about Feed formulas roamingdrone Glass, Plastic and Stone 2 09-22-2009 03:15 PM
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
drilling through 1" acrylic rod over 8"lenth jstwinbaby General Material Machining Solutions 3 12-08-2007 01:12 AM
Acrylic Mike7 Vacuum forming, Thermoforming Etc 2 10-30-2006 10:16 AM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
