I have seen UV glue used on glass to glass type applications, the strength is incredible, and found this with a bit of googling :
http://www.glass-etching-kits.com/uv...lue_orders.htm
It does say glass to metal for some of the glues, couldn't say if it is of any use to you, it is possible that the glue itself may act as an insulator between your coating and the copper, possibly the copper would go on first then the coating, if your process allows...
Other than that, its late, I tried
Good luck !
Russell.
LinkBack URL
About LinkBacks
