Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 03-10-2010, 02:51 PM
airfidget is on a distinguished road
Injection Mold Venting
Newbie to CNC Zone and injection molding. Need some help figuring out what a typical vent size is. I'm using Morgan-Press injector rated for 12 tons, and I'll be using low density polyethylene. It's a very small mold compared to some I've seen, it's got about 18 square inches of surface area on the inside including the gates and the sprue, and it makes 4 caps at a time. Any help anyone can give me would be awesome.
Old 03-11-2010, 12:38 PM
JCMills is on a distinguished road
Vents for plastic injection molds
Im not the king of vents but try parting line vent the entire cavity if it is flat. It depends on how flashy your material is. If its very flashy then .0006 might be necessary--if its low density something then it may not flash hardly at all and you might go deeper such as .0010. then just do a groove with a ball end mill maybe .020 deep that goes into that undercut area and run the groove to the outside..with the groove coming up maybe .100 from the edge.. Also when molding and having vent problems dont forget the tape and shim trick between the platens to space them apart.. I am a big believer in venting the entire periphery of the cavity even though it gives alot of people the willies. A good rule of thumb is that when venting that you probably need MUCH more.. keep in mind that a true full periphery parting line vent gives not less then TWENTY TIMES the venting....at the same depth. If .001 will not flash--then there is no logical reason to be afraid of venting the entire cavity. This proves out in actual practice and not just theory..
Old 03-25-2010, 10:48 PM
anchange is on a distinguished road
I just made my first injection mold and shot it this weekend. Used PP and some other plastics. My vent lines were .0015 deep with a 1/8" cutter and there was no flashing at all. I faced the piece with the same cutter so that I wouldn't lose tolerance with a tool change and they'd be exactly .0015
Old 08-14-2010, 01:11 PM
and of course the smaller a mold is--the tighter it will shutoff so venting can become more important. A large mold with ej pins and unusual parting line--they automatically are usually venting all over the place. Even down the pin holes especially--and remember--ej pins are never greased--they are always installed bone dry.
[IMG] code is Off
Need A Quote- RFQ Injection mold polycarb dandy7200 Employment Opportunity 2 03-24-2010 09:35 AM
I need injection mold help... anchange Mentors & Apprentice Locator 11 12-31-2009 07:12 PM
injection mold basics help anchange Moldmaking 1 10-23-2009 09:10 AM
Injection Mold and Initial Production Run Cooperd0g Employment Opportunity 13 09-06-2009 10:38 PM
How to design a injection mold thanhct Moldmaking 5 04-01-2007 06:45 PM
