Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 03-02-2010, 07:56 AM
simonfilm is on a distinguished road
Cutting plastic discs
I need to cut a disk like this http://www.dfocussystem.com/images/marking2_thumb.jpg.
It can be nylon, polythene, kevlar, etc. The big diameter is almost 100 mm ( 4 inches) and 5 mm thik. I have thought two aproachs. With a round bar. Here the problem is to part it on the lathe. The other aproach is with a plate. Cut a cirle and put it in the lathe. Here the problem is that is very thin and can bend in the chuck.
Any idea?
Thank you very much!
Old 03-02-2010, 09:12 AM
rowbare is on a distinguished road
Do you have a drill press? Get a couple of hole saws and cut them out of flat stock. Do the small hole first and use the same guide hole for the large saw.
bob
Old 03-02-2010, 09:30 AM
pofo is on a distinguished road
I'm no machinist, so don't listen to me. But there is a video on the M.I.T. site with a series of machining videos. He shows how to cut thin material on a lathe using a plate with double sided sticky tape instead of a chuck. He cut aluminum on it. He cut a disk with a hole just as you show.
I would think it would be even easier with plastic.
It's one of the videos in this series. http://techtv.mit.edu/genres/24-how-...machine-shop-1
Old 03-02-2010, 09:48 AM
SanDiegoCNC's Avatar
SanDiegoCNC has a little shameless behaviour in the past
Any idea?
This is probably best cut on a waterjet or cnc laser if you have access to either.
The next best way would be to use double-back tape and cut them on a cnc mill.
Lastly, if you cut them on a lathe, you'll have to do so with a chuck since the diameter is so large. Using nylon will be a problem with a lathe because it has a tendency to flex while cutting, even with a sharp insert like an NPR parallel (0.004 R). Also, you would need to use a cutoff blade (0.123 wide) to reach the desired depth during cutoff. That presents the biggest problem... having the cutoff blade extended out so far makes for a less rigid tool. If you do decide to machine this on a lathe, be sure to adjust your home position in 'X' away from the sheet metal, otherwise you'll crash when the tool indexes.
Hope that helps!
[IMG] code is Off
4 inch cutting discs nc9933 General Metalwork Discussion 0 12-20-2009 08:55 PM
Newbie- Cutting Sheet Plastic swamper8 Laser Engraving & Cutting Machines 5 07-19-2009 07:19 PM
Cutting Discs Challenge ! Smith & ARROW Product Announcements & Manufacturer News 2 09-09-2008 04:35 PM
CNC plastic cutting help! woox Glass, Plastic and Stone 2 08-28-2008 02:54 PM
Any innovative ideas for cutting acrylic flat sheet into discs? SRT Mike General Metalwork Discussion 6 08-17-2008 08:17 PM
