Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 02-24-2010, 07:44 PM
hackmeister is on a distinguished road
Drilling UHMW
I was drilling some uhmw the other day using the tailstock on an engine lathe and had a difficult time getting the size hole I needed. The hole ends up being about .005-.007 undersize what the drill is (.750) I was able to make it work by using an adjustable reamer, but the finish was poor. What do you do to make a drill cut to size in this uhmw stuff?
Old 02-24-2010, 10:36 PM
judleroy's Avatar
judleroy is on a distinguished road
If you can use flood coolant that should help since the plastic swells alot when it gets hot and then shrinks when it cools off. I have only really had good luck with holes being accurate when I finish an undersized hole with a boring bar. Shoot for thicker chips(more
like an old telephone cord) and drill fast enough to get a similar chip. The thicker the chip the faster the heat is disipated from the material.
Judleroy
Old 02-26-2010, 06:20 PM
Thanks judleroy. No flood coolant on the lathe I was using. Would double drilling work? Use a drill about .030 under and then shoot for size. With most of the material gone heat should not be a problem, right?
[IMG] code is Off
UHMW alternative? theatrewizard Linear and Rotary Motion 6 10-15-2008 08:19 AM
Milling UHMW tanky321 DIY-CNC Router Table Machines 11 03-29-2008 07:56 PM
Where to buy UHMW Breaker DIY-CNC Router Table Machines 10 02-04-2008 09:41 AM
UHMW Polyethylene Eric Nelson CNCzone Club House 2 01-26-2005 04:15 PM
melting UHMW Hobbiest DIY-CNC Router Table Machines 9 02-09-2004 03:42 PM
