- Underwater machining ?
Re: Underwater machining ?
Here is a link to our drill supplier
Applied Matrix
Drills range in size from .075" -3" diameters
300-500 sfpm
.0003"-.001" feed per revolution
I have drilled granite surface plates using these feeds and speeds
Hi tc26
Valuable info! Thank you.
Cheers
Roger
You are welcome.
Thank you
This might work in your case
In the past I have used diamond hole saw drills to make 2" holes in 3/8 glass. Using clean water and a clay dam around the area to be drilled. fill clay dam around the tool with water keeping the tool underwater at all time. chip removal was simple flooding over the dam with clean water. when it started to look like milk I poured more water and let it flood over the clay dam .
Hi emd68
References from customers are apreciated - thanks.
Cheers
Roger
- You may not post replies
- You may not edit your posts
Forum Rules
