Underwater machining ? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Underwater machining ?
  1. #21
    Sep 2007
    Default Re: Underwater machining ?
    Here is a link to our drill supplier
    Applied Matrix
    Drills range in size from .075" -3" diameters
    300-500 sfpm
    .0003"-.001" feed per revolution
    I have drilled granite surface plates using these feeds and speeds
  2. #22
    Jun 2010
    Hi tc26
    Valuable info! Thank you.
    Cheers
    Roger
  3. #23
    Sep 2007
    You are welcome.
    Thank you
  4. #24
    Member emd68's Avatar
    Mar 2008
    Hello Roger,
    You could also try Wrisley Abrasives for diamond tooling.
    Diamond Tools - Wrisley Abrasives - Diamond Tools - Wrisley Abrasives - Home
  5. #25
    Member mountaindew's Avatar
    Nov 2007
    earth
    This might work in your case
    In the past I have used diamond hole saw drills to make 2" holes in 3/8 glass. Using clean water and a clay dam around the area to be drilled. fill clay dam around the tool with water keeping the tool underwater at all time. chip removal was simple flooding over the dam with clean water. when it started to look like milk I poured more water and let it flood over the clay dam .
  6. #26
    Jun 2010
    Hi emd68
    References from customers are apreciated - thanks.
    Cheers
    Roger
