- Thin plastic engraving?
Hello guys
I own a 6040 CNC machine which I'm using (still leaning..) to cut thin 2-3mm plywood and 3mm styrene.
My questions for you today is: what would be right way to engrave the materials, thin engraving 0.15mm wide and about 1mm deep. will it be possible to use drill bit? I have some small lines to engrave at the surface (V shape bits wont do the work)
Thank you in advance
Re: Thin plastic engraving?
I don't think a drill will work well, the cutting geometry is wrong.
Would something like this work? https://bitsbits.com/index.php?main_...c2f83391b8bb90
It still as some taper, but it's minimal. I have used these to cut all the way through 0.028 (0.6mm) brass.
Check out Harvey tool. They have some tiny ballmills. Ive gone as small as .010
- You may not post replies
- You may not edit your posts
Forum Rules
