- Need Help!- 45 Degree Chamfer (9mm Plexi/Acrylic) on CNC-Router
Would appreciate if anyone can please point me in the right direction....
I have a 9mm plexi/acrylic product onto which I want to Chamfer a 45degree on the outside edge. The chamfer should be from top of the stock to the bottom so it is more or less 13mm tooling/cutting distance. I can do it with a ballnose with small passes but it takes way too long.
My Question: Anyone know of a 45 degree endmill that I can use to do this? I don't mind to do a few passes to get right down but with the ballnose it is about 50 passes to get the chamfer smooth and takes very long.
Thanks in Advance
Re: 45 Degree Chamfer (9mm Plexi/Acrylic) on CNC-Router
Any store that sells endmills should have a 45 degerre chamfer mill.
Just make sure its long enough.
Cutting should be way faster than with the ball endmill.
Have fun: Heinz at doccnc
- You may not post replies
- You may not edit your posts
Forum Rules
