I don't have a clue really, but none of what you just said sounds right.
I suppose you will be using diamond bits?
If you have enough spares, I would say this will warrant a bit of testing.
I am interested in the results.
Hot glue may work too.
Hey Guys
I need to machine a profile out if a microscope slide pc of glass?
#1 What is best way to hold it because of how thin it is?
I was thinking double sided tape but what would be best way to remove it afterwards? Or some kind of vacuum set up
#2 Should I cut it in a water bath? Or just with coolant?
#3 I'm machining it on a Bridgeport retrofit and do not have high speeds will that be OK?
#4 I What would be the best tooling to use? I'll need appx a .062 corner rad
Thanks for your help
Mike
Lee
Glass is cheap.
Give it a whirl.
Lee
I'm sorry, but don't bad things happen to people that breath in tiny glass chips? I would certainly protect myself.
Normally glass would be manually shaped on a grinder spindle, if it's a simple profile your after that can be followed along an outline manually, maybe setup a grinder or abrasive bit in the mill quill lowered down, and guide the glass along the pattern?
Machining glass requires absolute rigidity, anything less and it will break.
cheers, Ian
It's a state of mind!
You might try scribing the glass with a single-point diamond tool and breaking it to the profile. That would go a lot quicker than trying to rout it. Double-sided tape would work to hold it down, or a vacuum pod. Some lubrication would be advisable. The spindle speed wouldn't matter, since you wouldn't be spinning the tool. A spring-loaded toolholder might help.
