Need Help! Vacuum pump for degassing resin & silicone
Results 1 to 19 of 19
Thread: Vacuum pump for degassing resin & silicone
    Sep 2011
    Thailand
    Default Vacuum pump for degassing resin & silicone
    Hi, I'm looking to buy a vacuum pump to connect to a chamber for degassing polyester resin and RTV silicone. I've seen this one for sale in an air conditioner sales shop but not sure if it will do the job. I understand I need around 29 inch of mercury vacuum to degass successfully but this model is in PA.
    The specs are
    1 stage vacuum pump
    3.5 CFM,
    ultimate vacuum - 10PA
    1/3 HP
    Anybody know if this is good enough?
    thanks
    Attached Thumbnails Attached Thumbnails Vacuum pump for degassing resin & silicone-img_1962-jpg   Vacuum pump for degassing resin & silicone-img_1963-jpg
    Registered johnohara's Avatar
    Aug 2008
    www.johnohara.net
    By comparison, this HF vacuum pump is 3CFM and pulls down to 25 microns:
    Air Conditioning Vacuum Pump - Two Stage, 3 CFM
    Some other (hopefully) helpful links:
    Vacuum Gauge Tech
    Vacuum Pressure - Converting Units
    Pressure Units Online Converter
    ~John
    Sep 2011
    Thailand
    Thanks. Some interesting information there. The harbour freight pump looks like it would do the job from the reviews, But as I'm living in Phuket / Thailand, this is the only pump available to me. I tried some of the online conversion tools but apparently 29 inches of mercury is equal to 100000 PA (and this pump only creates 10 PA!!). Surely that cant mean this vacuum pump needs an ultimate vacuum 10,000 times more to create 29 inHG ??
    Oct 2005
    It's probably 10kPa. Single stage pumps will work ok for vacuum bagging and some light degassing, but generally you need a dual-stage pump to get the higher vacuums needed for good degassing, especially on very thick liquids like silicone.
    No single stage pump of that type will give you 29 inches of mercury!
    Aug 2008
    www.johnohara.net
    jontidy~
    Here's are some links to Freeman Supply that should help.
    Vacuum Degassing & Pressurizing
    FMSC - Gas Vac II Industrial Vacuum Degassing Unit
    Freeman Supply's web site is full of great information. They are very generous with their product knowledge and expertise. A must visit.
    ~john
    Jul 2005
    Normal atmospheric pressure is 101kPa, i.e. 101,000Pa (as mentioned).
    If that pump can indeed pump down to 10Pa it is pumping down to less than 1 ten thousandth of an atmosphere; 10/101,000
    That is a good vacuum and is much better than 29"Hg.
  7. #7
    Sep 2011
    Thailand
    Quote Originally Posted by Geof View Post
    So even though this is only a single stage pump, at 10PA it would be able to degass silicone right?
  8. #8
    Jul 2005
    Yes the vacuum it develops will be more than enough. I notice from the nameplate that it mentions oil capacity so it must be an oil immersed vane pump. These are the type used in laboratory applications.
    If you do get a pump like this and use it for degassing silicone you MUST make sure you have a reservoir tank between it and the silicone and also a filter between it and the tank. These will slightly reduce the efficiency of the system but if you omit them and fill the pump with silicon froth the efficiency will be reduced to nothing.
    I am guessing you have not done any silicone degassing yet. I have and fortunately I was not using an expensive pump the first time, I was using an air aspirator, a venturi valve that created vacuum from a high pressure water flow. When I applied the vacuum nothing much happened at first. Then when the vacuum got down to somewhere about 25" Hg the silicon frothed up and 'boiled' out of its container and filled all the tubing with silicone. In this way I discovered that you needed a container with a volume about three times larger than the silicone being degassed and you need something of larger volume between this and the source of the vacuum.
    Once the silicone has frothed and then settled down you know that it is successfully degassed.
  9. #9
    Sep 2011
    Thailand
    Thanks for the info Geoff. I think I did see on the box it comes with that this is a rotary vane pump. Its for sale in a Air conditioner repair shop so I guess its for removing the moisture from Aircon units. They also sell a smaller pump (just 2.5 cfm and 5 PA ultimate vacuum) for 1900 thai baht (about $60), but I guess this wouldn't be good enough because its so cheap. The bigger one is about $100.
    When you say a reservoir tank and filter, Do you mean an air tight container with the pipe from the vacuum chamber going into it, then out of it and into a normal air filter (the types usually connected to air powered machinery to remove the moisture). Then the pipe running into the vacuum pump?
    Sorry for all the questions, just want to get the right equipment as cheaply as I can as I've already wasted enough cash on ruined silicone moulds full of bubbles.
  10. #10
    Jul 2005
    For the filter enquire at the place you get the pump. Just using a regular compressed air filter may not work because the filter housing could collapse when subject to vacuum.
    The reservoir tank can be anything that does not collapse due to vacuum. You could construct one out of heavy plastic pipe using varnished plywood as the end caps. All that is needed is a volume that would allow any silicone bubbles sucked down the line to settle out before reaching the pump with the filter as a secondary backup.
    The plumbing sequence you describe is correct: Degassing chamber to reservoir, other end of reservoir to filter, filter to pump. Put a ball valve between the degassing chamber so you can pump the reservoir down while you are mixing the silicone and you will save time.
  11. #11
    Oct 2005
    That's impressive! My single stage pump won't pull anything close to that. Normally it's recommended to use a 2-stage pump for good degassing.
    I hope it's not a case of "enthusiastic specs label" that happens on some Asian equipment sold on ebay?
  12. #12
    Jul 2007
    jontidy, watch the vaccum degassing video that John linked to and you will see what Geof means, the silicone will increase in volume and then collapse as the air is removed.
    A lot of people use a paint pressure pot for degassing (something like this: Paint Pressure Tank - 2-1/2 Gallon). You would put your container inside the pot. In a pot that size, you would probably do 1 litre at a time in a 4 litre pail.
    bob
  13. #13
    Sep 2011
    Thailand
    Thanks Bob. When I decided enough was enough with all the bubbles in my moulds, I did a lot of research about vacuum degassing and watch a lot of videos. Just wasn't sure if the pump in question would be good enough for the job so thought I'd ask you nice people at CNC zone. So next job I guess is to try and construct a vacuum chamber as they dont sell them here in thailand and for what they are I think there a bit expensive to say the least.
  14. #14
    Jul 2007
    I imagine you should be able to find a paint pressure pot. Check with an auto body shop, I am sure they could point you in the right direction.
    bob
  15. #15
    Jul 2005
    Quote Originally Posted by jontidy View Post
    ..... So next job I guess is to try and construct a vacuum chamber as they dont sell them here in thailand and for what they are I think there a bit expensive to say the least.
    How good are your wood working skills? Plywood with a resin coating inside and out will probably work fine. You do get some bleed of air, and water vapor, out of the wood under vacuum so you will never get down the the 10Pa the pumps is capable of but you should get down low enough for the degassing.
    Alternatively make one entirely out of fiberglass laminated up to about 1cm thick, or thicker.
  16. #16
    Sep 2011
    Thailand
    I was thinking of using a paint pressure pot for the chamber, then I could also use it for pressure casting the resin to further eradicate the bubbles. Failing that I was going to try and find some of the large PVC water pipe stuff they put underground and using two pieces of 1/2" thick clear acrylic sheet to seal the top and bottom of it with the hose and vacuum gauge screwed into the top piece of acrylic. I know the acrylic would withstand the vacuum but not sure if the large diameter PVC pipe would?
  17. #17
    Jul 2005
    The pipe probably will be okay but just as a safety precaution wrap in it some fabric; carpet, canvas, blanket, something that will confine any fragments if it does decide to implode.
    Depending on the diameter of the PVC pipe 1/2" acrylic may be marginal. On a 12" (30cm) diameter pipe 1.2" is probably not adequate. Remember you are drilling and tapping into the acrylic which introduces a weak spot.
    On the topic of drilling and tapping the acrylic. Use only new drills that have never drilled metal and taps that have never touched metal. If you have a bench grinder grind a small flat on the cutting edge of the drill so that the cutting edge is flat, not sort of hooked as occurs because of the helix of the drill. Clamp the acrylic very securely because it has a tendency to grab onto the drill. If the cutting edge of the drill is not ground flat it has a very strong tendency to screw itself into the acrylic just like a big wood screw. This normally results in a broken drill, a broken piece of acrylic and badly bruised fingers, or worse.
    You are probably planning on using a tapered pipe thread. With a tapered thread it is possible to put great stress on the acrylic which is not a good idea because acrylic is prone to stress cracking. Use teflom tape and a bit of silicone grease if you can find it, on the thread but only screw it in finger tight to avoid overstressing the acrylic. If you get a leak here rather than screwing it tighter smear some of your RTV silicone around it to provide a seal.
  18. #18
    Sep 2011
    Thailand
    Thanks Geof for the really good advice. Glad I've found out about the acrylic thickness and fabric tip as the word "Implode" scares me a bit. I suppose I will need to use some sort of strengthened tubing to connect all the bits (chamber/overflow/pump) which wont collapse under vacuum too.
  19. #19
    Jul 2005
    Yes you will need tubing that will not collapse. In science labs normally it is just very thick wall rubber. I have used the reinforced tubing that is used for connecting hot tub and swimming pool pumps. Probably any flexible PVC tube that has a wall thickness equal to the inner diameter (if you can find it) will work.
