Results 1 to 5 of 5
Thread: Watertable depth?
    Feb 2007
    Watertable depth?
    I have a 4x4 table made out of 80/20 3030. I'd like to add a water
    table to it but I am concerned about the weight and how much depth
    do I need. Would 1 or 2 inches of water help?
    What do most of you make you water table out of? Galvinized sheet metal?
    How do you regalvanize the welded corners so they dont rust?
    I am hoping to bolt the water tray to the xaxis where the slat holders are
    currently bolted to and then run a bottom support down the middle
    of the tray underneath.
    Thanks,
    Mike
    Sep 2003
    hamilton
    Mike:
    Most people are making the water table out of mild steel and putting a rust inhibitor in the water.As far as how deep it depends on how thick you want to cut.Usually water tables are 6-7" deep but I have seen some only 2" for doing thin sheet metal.As far as touching up welds on gal there is a product that you can spry on to re-galvanize.
    Cheers
    Kirk
    May 2003
    Illinois
    water table depth
    Sir,
    We had a customer on the west coast who cut very thin material; his water table was only about 2" deep and it served him well.
    As a matter of fact. in order to minimize warping on his thin stuff, he had the water level such that his workpiece was just barely covered by the water. When the torch was turned on, the air/gas blew away the water just in the vicinity of the torch tip, and the result was that the remaining water carried away the cut heat very well with no warping.
    Regards,
    Jack C.
    Jul 2008
    I built my water table out of 16ga stainless sheet. There was a thread last week discussing water table depth. 1" or 2" of water would definitely be better than none at all...
    Registered Weldtutor's Avatar
    Oct 2005
    Arrow Water Table
    Quote Originally Posted by DeviousMW View Post
    table Would 1 or 2 inches of water help?
    currently bolted to
    As pointed out above the water is quite effective if close to (or very slightly above) the top surface of the material being cut.
    To be most effective for dust collection, position your slats inside the water tray, then water level can be raised to the top of the slats or top of material being cut.
    Various water depths are used by builders.
    My system works well. It is 4" deep with the slats submerged 2" into the water, with the slat top surface normally level with the water surface.
    Check HERE for information in posts # 161 & 164.
    A drawing is in #166 & a picture in # 176.
    1. Downdraft or watertable?
      By nzben in forum General Waterjet
      Last Post: 04-08-2008, 04:41 PM
    2. Downdraft VS. Watertable
      By NoLimit in forum General Waterjet
      Last Post: 12-12-2007, 08:27 AM
    3. What RPM/Depth of cut?
      By sp1nm0nkey in forum General Metal Working Machines
      Last Post: 04-07-2007, 11:45 PM
    4. Water Circulator for watertable cutting of Aluminum?
      By Knut in forum General Waterjet
      Last Post: 02-26-2007, 01:35 PM
    5. Npt Depth
      By ryanduc in forum General Metalwork Discussion
      Last Post: 06-23-2005, 05:24 PM
