Sir,
Are you looking for the CNC controller to run the sterpper/servomotors, or do you want an auto torch height control? Both are available for very reasonable sums. A most popular CNC controller is the Mach 3 series. And others on this site can recomment a ready made THC. Note that you will need the table and carriage, Z axis mechanism, motors and gearboxes and gear rack, stepper or servo drivers, interface cards, and plasma unit to accomplish this.
Give us more info as to where you are at this time.
Regards,
Jack C.
LinkBack URL
About LinkBacks
I already have a Thermal Dynamics Pak 50 which I have used manually for a few years. I mostly cut 1/4 steel plate. Gaining the ability to cut out brackets and such with the table would be extremely helpful.
