Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 53
Thread: adding thc to burny control
    Sep 2006
    UK
    hi there, i'm taking delivery next week of a used 3m x 1.5m plasma machine (servo driven) running off a burny 2.8 controller (apparently a 2.8 is just a 2.5 mounted in the same console as the servo drives and psu etc.)
    It has a plate rider, ie no thc, and i'm wondering whether it's possible to retro-fit a thc to run off the burny. I don't have schematics for the burny (if anyone has, I'd be grateful for a scan!)
    if the burny dies in the future i'd probably go the mach route rather than shell out big money on a repair, which would enable me to add the thc quite easily, but i'd rather just slot one in to the working system for now.
    The plasma source is a hypertherm max 100 (100A o/p) with a machine torch. I heard that hypertherm do a thc, but i don't know whether it needs interfacing to the control.
    Is anyone here a burny/hypertherm expert?
    thanks for any advice
    Nov 2006
    Scotland
    What machine is it?You should be able to download the manual from the Burny site.
    Sep 2006
    UK
    gridley51 , thanks for the reply, I looked at the burny site, but you have to download a form, manually fill it in and then fax it back to them before they will let you download anything. I'll probably do it, but I gave up on fax years ago, so it's a bit of a pain.
    The machine is an Esprit Lightning, I called Esprit and they said it wasn't worth adding a thc, presumably because they'd recommend a control replacement. I was hoping to find a reasonably-priced option.
    Aug 2009
    Hypertherm has a couple THCs. Their Sensor THC is great. Simple. What type of Burny controller do you have? I can get a hold of all of the schematics. Also, what type of drive/motor combo are you using for the Torch(Z) axis?
    Sep 2006
    UK
    Quote Originally Posted by justinhosley View Post
    hi justin, it's a burny 2.8 (see pic below, if I've done it right), which is just a 2.5 built into a case with all the drives.
    as for motor/drive for the z axis, I was going to wait until I sourced the thc control and buy something that would be compatible. It would probably just be a gecko-stepper combo if i can get away with it.
    Nov 2006
    Scotland
    I have the maintenance/operator manual for the Burny DNC 2.8 plus and the maintenance manual for the Burny 2.5 as fitted to a Messer m/c.Messer told me it`s really a 2.8.They are on pdf`s if you want them.
    BTW I was thinking about thc but from what I read on the forum here decided I`d wait and see how it went once the m/c was installed.
    Sep 2006
    UK
    Thumbs up
    Quote Originally Posted by gridley51 View Post
    yeah, I asked the previous owner whether he'd had any problems with the plate rider, and he said it had been pretty good really- you just have to watch when leaving narrow strips between parts, or when doing small parts. If it does catch, you can lose a whole sheet if it gets dragged along.
    I will be using it in its current state at first anyway, so I'll get a feel for it, but it does sound like the cut quality can be improved with the thc, as well as eliminating crashes. I've been reading about how the better ones work with the controller to compensate for the speed changes at corners etc, so the thc doesn't panic and dive the torch. That's why I was interested in the schematics to see whether there were pins on the controller for this purpose.
    I'd be grateful for the schematic- I'm not too knowledgeable about forums- what's the best way of getting a copy from you?
    thanks for taking time to respond http://www.cnczone.com/forums/images/icons/icon14.gif
    Nov 2006
    Scotland
    Steve,if you click on my name above,you will be given the option of sending me a private message.Use that to send me your email address.That`s if you`re not a mile down the road from Broxburn.
    Jan 2008
    The Hypertherm Sensor PHC height control is a great standalone THC system...it features ohmic and stall sense for finding the plate surface (necessary for good pierc height) as well as a very accurate arc voltage feedbeack process for real time height control. here is a link for more info:
    http://www.hypertherm.com/en/Product...sensor_phc.jsp
    Jim Colt Hypertherm
    Sep 2006
    UK
    Quote Originally Posted by jimcolt View Post
    Jim Colt Hypertherm
    thanks jim, that does look good, although it does require several connections to the cnc control to tell it when the arc is good etc- I'll have to check whether my burny has these i/o pins, and whether it needs any reprogramming or setting up to look for these inputs and send the outputs. Do you have any idea how much roughly they sell for? Or who the hypertherm agent is for london, i cant seem to find one with google. thanks.
    Jan 2008
    The THC requires a plasma start output....and needs a avc disable..or corner output function that freezes the THC during cornering. Your Burny has these signals.
    If you go to the Hypertherm website www.hypertherm.com you will find contact info for our European offices...they can direct you to dealers...our tech service department can assist you with proper connections to a Burny as well.
    Jim Colt
    Apr 2009
    Burny 2.8 Connections
    It is easy to connect a THC to A Burny 2.8
    The 3TB treminal strip (in the rear of the cabinet) is where you connect the THC (any type)
    The Plasma Start Contacts are 15 & 16
    The Height Freeze Contacts are 19 & 20 N.O. and 19 &18 N.C.
    Cut Sense Input is 1 and for a 24 Volt Signal 2
    120 Volt Signal 3
    220 Volt Signal 4
    You remove your plasma interface, connect the THC to the 3TB termionals and connect your plasma to the HTC per the mfg instructions.
    Be careful with the Hypertherm THC's.
    Their Cut Sense outputs are only rated for 24 Volts DC at 15 ma. You can destroy them easily. Most other brands use a relay contact output.
    The Burny 2.8 input requires you supply 24VDC if using a Hypertherm THC for cut sense.
    Most others with a relay output you can use any voltage (AC or DC) available.
    I have attached a few pages I scanned from a Burny 2.8 Plus manual. That is the newer version, but the interface is the same.
    You can request the manual from www.burny.com, or call Tech Support in Cleveland and they may have a copy of the 2.8 manual available as a .pdf.
    Burny Division
    7550 Hub Parkway
    Cleveland, Ohio 44125-5794
    Telephone: 216 / 524-8800
    Fax: 216 / 642-2199
    Be patient as it sometimes takes a while to get through to them.
    Good Luck
    Attached Thumbnails Attached Thumbnails adding thc to burny control-burny_2_8_plusinterfacedf.pdf   adding thc to burny control-burny_2_8_plusinterfacedfwiring.pdf
    Alan Bradford
    www.plasmatechnologies.com
  • Page 1 of 5 1234 ... LastLast
    1. anyone got burny 2.5 parts???
      By xjdubber in forum General Waterjet
      Last Post: 09-15-2009, 08:11 AM
    2. Need Help!- Adding More RAM for A Fanuc Control
      By tricky in forum Fanuc
      Last Post: 03-15-2009, 10:49 AM
    3. Autocad to Burny 5 Help, Newbie!!!
      By waparson in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 05-19-2008, 12:46 PM
    4. adding camsoft control to an omniturn
      By scolee in forum CamSoft Products
      Last Post: 10-20-2007, 09:09 PM
    5. Burny comunications
      By Jonp in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 12-30-2006, 10:35 PM
