Results 1 to 10 of 10
Thread: Need help
    rai
    rai is offline
    Feb 2006
    INDIA
    Need help
    I have a Fanuc Tape cut Model WO wirecut edm machine, I looking for it's manuals. Somebody provide me the manuals for the same.
    rai
    rai is offline
    Feb 2006
    INDIA
    help me please!!!
    somebody provide me it's manuals. I am still waiting for help..........
    Oct 2010
    I have an old W1 machine with some problems am i in the right place
    Aug 2008
    united sates
    You can get manuals from Fanuc ....Whats your problem ?
    Sep 2008
    England
    I bought W0 manuals and Technology earlier this year from fanuc new. they were very helpfull but warned me from the start that there is around a 12 week wait as no stock and print to order on these older machines.
    you might be lucky and they ran off a few while doing so.
    Oct 2010
    The problem that I am having is that the machine will move through the lines of code until it gets to the G01 comand and then sets there dumb. I can push the dry run button the generator shuts off and then the machine will start down the G01 codes until it finishes the program.
    Sep 2008
    England
    I'm new here and to EDM but have you allocated any offsets and technology? has the program read this yet? is there anything set under the cutting conditions number you have assigned in the program? if so even if you forgot to set a wire feed value the machine will stop at this position after moving under G0!
    Oct 2010
    Yes to these questions, This was a program that we ran before many times.
    Aug 2008
    united sates
    If you checked everything you can ....fuses ...relays....24 volt transformers ..input voltages...machine limts swiches ...door interlock switch....check everything....If you find nothing wrong reload parameters...Then post back.......
    Oct 2010
    Ok thanks I have checked fuses made sure that relays are not welded close alot of swithches have been jumped out by someone before me voltages and power supplys check out. I have not reloaded parameters! How do you reload parameters ? And also isn't wierd that I don't have any error messages.
  • Posting Permissions
