Results 1 to 11 of 11
Thread: SODICK WIRE EDM MARK 21
    May 2006
    VietNam
    Exclamation SODICK WIRE EDM MARK 21
    Dear All.
    I have SODICK A500 wire cut edm machine.
    I can not transmit and received data via RS232 interface. I do not known why although i used cable same with fanuc cnc. operation follow with sodick manual.
    Now i must use floppy disk for transmit data from pc.
    I have 02 user disk from sodick but i don't known the way to read and write that disk. For testing I installed windows 98 and windows 2000 but my computer can not read and write floppy.
    Anybody have experiment for this case please show me the way to solve this problem.
    Thanks in advance.
    BKCOM
    Nov 2008
    Argentina
    Mr BKCOM,
    that generation of sodick machines had an specific issue with serial, wich had something to do with the bit transcription of the serial. I can't tell you precisely what that is, but it is not an easy thing to solve with an ordinary pc. Sodick used to provide a separate pc unit to program, with the same soft as the machine, and that worked fine, naturally.
    As wire cut programs don't have so many blocks, they are easy to copy on disks, but you must use the 720k format, instead of the normal 1.44mb. First of all, do not format disks on the machine, but in the pc. If you can format them in 720 (it is an option that win98 normally has), there´s an even more simple solution. 720k format it is not more than a one-side format. Have you ever realized that floppy disks have TWO holes in the corners? One is to protect them from writing, and the other one is to block one side of the disk. Cover it with a tape, and the disk will automatically become into a 720k one. Try these two options, the file extension for sodick is .nc, from a normal text file. You should be able to make it work so.
    PS: this has just one problem. Disks normally become useless after a couple of weeks, due to electric noise from the machine. I found just one solution to that... I bought many of them. Hope was helpful
    Oct 2006
    to fomat floppy 720k on xp or dos download FMTW.exe
    i have it to format on xp po my 720k
    work verry goot
    i have a sodick a530d ..
    if you dont find it on the web replay me
    i have it on zip files si posible to send it to you
    sorry for my english i talk french
    Dec 2006
    the link below is a pinout for the sodick cable. Your cable pinout for the fanuc may be different than the sodick machine. Check in the parameters for parity check and what baud rate the machine is set to also. If you start to get info but it is all messed up change the baud rate. there is a device sold for rs232 connectors that can test the cable coming out of the machine and also the cable coming from the computer. I hope this helps you.
    http://www.sodick.com/forum/showthread.php?t=737
    May 2009
    India
    Regarding Sodick mark 9 BF 275
    Dear sir
    recently I purchased a used Sodick mark 9 BF 275 wire cut macine, the machine is showing an error " SYSTEM ERROR" with red color background, can u tell me where the problem is? if you can help me please send me the details immediately to my e mail : srikrish_madurai@yahoo.com
    Thanking you
    Srikrish
    May 2010
    india
    HELLO ,IM USING A350 SS AND FACING PROBLEM WITH SMS BOARD ,VERY FREQUENTLY MOSFETS ARE GETTING FAILED , WIRE GETS BURNED COULD NOT FIND OUT THE PROBLEM , PLEASE HELP ME WITH THIS. PLEASE MAIL ME AT naveinr@yahoo.co.in
    Dec 2009
    INDIA
    Thanks for the info,
    I've recently purchased a A320D-AWT, & i'am facing the same problem , I am trying to load program from my windows xp , but m/c doesn't reads it , so I Blocked Right Hand Side slot , formatted the disc in the m/c on 720kb & then re-write the program , and again tried to load on the m/c , but m/c doesn't accept it ,
    Should i go for another pc with o/s WIN 98 ? Or any other way out ?
    Systronic:- could u send me files for FMTW.exe
    email:- mescotc@sancharnet.in
    May 2010
    india
    Unhappy PLEASE HELP ME
    HI ALL PLEASE help us solvin , I HAVE A350SS SODICK FROM FOUR MONTHS M/C IS NOT WORKING , IF TRY TO RUN M/C, IT RUN'S FOR FEW HOURS AND THE WIRE STARTS TO BURN AND CREATS A MARK(LIKE SOLDRING) ON NOZZLE COVER AND THE MOZFET BLASTS IN SMS BOARD ,AND IF AGAIN WE TRY THE M/C TO RUN AFTER CHANGING THE MOZFET , THE SAME RESULT WE GET , PLEASE HELP ME BY GIVING SUGGETION TO OUT COME THIS PROBLEM,
    M/C IS NOT RUNNING FROM FEW MONTHS.
    IT WOULD BE A GREAT FAVOUR FOR ME.IF POSSIBLE PLEASE MAIL ME AT naveinr@yahoo.co.in
    Registered PLRElectronics's Avatar
    Dec 2008
    SODICK FLOPPY USB DRIVE
    Why dont you just upgrade the floppy to a USB port and eliminate all that.
    Floppy upgrades MARK X, MARK XI, MARK 25, MARK 21 - PLR Electronics Forum
    3 ½ floppy drive to USB flash drive reader upgrade
    Electronics Circuit Board Repairs and Design
    ber
    ber is offline
    Aug 2007
    Malta
    I NEED HELP PLEASE ON SODICK A320D EX21
    please can someone help me,i have a problem on my sodick a320d ex21, when it is loading it stops on system loading 12. can anyone help me pls? my email is sc.wedm@gmail.com
    *Registered User*
    Jan 2011
    India
    Sodick Collectioner ask me
    I have 5 Sodick Wire cuts I will be glad to help
    contact 00989175557355
    Ehsan.amouzegar@gmail.com
    I have a bf275 does not move axises during M00 code execution!
    What Should I Do?
    1. Replies: 9
      Last Post: 07-20-2008, 11:08 PM
    2. Sodick Mark X1B EDM Machine
      By rajappa in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 10-23-2007, 10:56 AM
    3. Rs32 connection for Sodick 327
      By edmpaul in forum General Waterjet
      Last Post: 03-28-2007, 10:01 PM
    4. sodick users
      By Graham S in forum General Waterjet
      Last Post: 12-28-2006, 03:17 PM
    5. Collets for Sodick SNT tooling
      By DareBee in forum General Waterjet
      Last Post: 03-08-2006, 09:38 AM
