Results 1 to 3 of 3
Thread: Hypertherm HD3070 question?
    Feb 2007
    Hi I'm looking to buy a Hypertherm HD3070 used to work with my home built plasma table. I have already a fabrication shop and i looking to make more parts (welded assembly and construction miscellanous) that I typically send to a laser shop. I'm looking to get better turn around time for small batch run. I have a couple of questions about it.
    Am I able to use Bob Campbell Thc with this system or i need a commercial one ?
    My other question is about the cost of consumable versus a basic Air plasma, is it more costly to initialy buy and then you save over the long run or you spend only for greater cut quality??
    What about all the gases that you need, how much can it cost to get me started ??
    I heard that you can also change the torch for a newer one is it worth it and how much does it cost?
    Thanks a lot for your help.
    Francis
    Jan 2008
    The 3070 is no longer manufactured....but it is still a very strong high definition class plasma system. There is a torch upgrade available from Hypertherm that allows you to use the new HPR130/260 torch on that machine....better cut quality and longer consumable life are the result.
    That system is a high frequency start torch.....so be sure you follow all of the best practices available for hardening your cnc control and electronics ffrom this source of electrical noise.
    The system has good consumable life as is...assuming it is operated as designed (follow all the procedures in the Hypertherm manual in regards to gas pressures and flows, cut speeds, arc voltage and pierce height). With the HPR torch it will perform even better.
    If you are only cutting carbon steel....you will need oxygen and nitrogen for this system when using the original torch....if you are using the new HPR torch.....you will use oxygen as the plasma gas and clean/dry compressed air as the shield gas.
    You can download a manual from the www.hypertherm.com website if you need one....be sure you specify whether you have an "auto gas" or "manual gas" system......the auto gas has all digital gas flow controls....while the manual gas version has flowmeters and gauges.
    Jim colt
    Feb 2007
    thanks a lot Jim,
    I will contact my hypertherm salesman for further pricing.
  1. Hypertherm -vs- Miller
    By ty1295 in forum General Waterjet
    Last Post: 01-05-2009, 04:23 PM
  2. Hypertherm or ESAB
    By gfelippo in forum Torchmate
    Last Post: 11-05-2008, 02:36 PM
  3. Need Help!- Will a Hypertherm 600 work?
    By Mick40 in forum General Waterjet
    Last Post: 07-23-2008, 05:50 PM
  4. Need Help!- Do I have to use Hypertherm for my cnc table?
    By vorapotwong in forum General Waterjet
    Last Post: 02-24-2008, 10:55 PM
  5. Hypertherm or not ?
    By zeoncomp in forum General Waterjet
    Last Post: 10-02-2007, 11:40 PM
