Results 1 to 5 of 5
Thread: Need suggestions for abrasive water jet nozzle shield...
    Jun 2008
    Hey guys I'm trying to come up with some ideas on solutions for shielding the cutting heads of our waterjets from the backspray during piercing. Unfortunately with the nature of the beast it cuts through everything eventually. What are you guys using? I'm hoping for something we can fabricate ourselves quickly and inexpensively with as long a life span as possible so let's see how you guys do it.
    Nov 2006
    A friend of mine on his Omat
    The least expensive toilet plunger you can buy (so it is flexable). Cut it to fit arround the nozzle. If it is flexable enough you can turn it inside out and it will stay there for set up and touch offs. Send me a personal mail if this wont work for you and I will look at it more in depth and call him also.
    Jetski
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
    Jun 2008
    Rubber
    I just use a 1/4" thick rubber that you can get from mcmaster. I cut about 30 of them 2 years ago and still have some left. I got tired of trying to find plunger heads and the plungers don't let you see a tip up.
    Scott
    Jul 2008
    tennis balls
    new member here
    We have an Omax 55 100
    Omax offers a nozzle shield for the carbide nozzles
    however, we sometimes use tennis balls when we are waiting on shields to arrive
    cut the tennis ball in half (makes two shields)
    drill .030 UNDERSIZE of the diameter of the tip on top of the hemisphere of the ball to ensure it squeezes on tight and stays put
    the tennis balls should have notches ("V" notches like saw teeth) cut around the perimeter of the cut so the pressurized water can escape the shield or "hood".....make them 45 degrees and a 1/4 inch deep all the way around the half a ball....or else the water will build up under the "shield" and disturb the jet stream a little bit
    has worked like a charm and is cheap, especially if you know somebody with some old free ones laying around
    hope that helps
    Jul 2008
    waterjet blast shield
    I have been watercutting for 9 years and by far the best material I have found to make a blast shield disc out of is urathane. It resists the blast of the jet for a long time and is flexible enough to give when it hits fixturing. Just cut an id od that fits over your nozzle or nozzle nut whichever you prefer. You can go farther and cut the disc more like a gear on the outside and cut strips that lock into the edge of the disc and hang down closer to the material if desired.
    watercutter
    1. Water transfer techniques for water table?
      By Knut in forum General Waterjet
      Last Post: 02-02-2007, 10:52 AM
    2. RFQ : Custom Erasing Shield
      By ukchris in forum Employment Opportunity
      Last Post: 08-13-2006, 12:36 PM
    3. RFQ : Custom Erasing Shield Wanted
      Last Post: 08-10-2006, 09:29 PM
    4. 5 axis Abrasive WaterJet
      By Lesh in forum General Metalwork Discussion
      Last Post: 09-18-2005, 01:39 AM
    5. Electrostatic shield on torroid
      By 2muchstuff in forum General Electronics Discussion
      Last Post: 05-24-2005, 08:57 PM
