Results 1 to 4 of 4
Thread: Wire EDM 4 axis Program
    May 2008
    New Zealand
    I have a Hitachi H-Cut 403N. I have successfully cut 2-axis (Mode 0 )and Standard taper (Mode 1) profiles. I have not managed to do any 4 axis cuts.
    I have tried various programs using different post processors, and manual programs but I cannot get the U and V axis to move at all.
    Does anyone have a sample program I could have a look at?
    Are there any parameters that need changing in the machine?
    Could it be that I should be using inc or abs or a special G code?
    I have set the Taper Cutting Mode to 2 on settings page 4.
    Iain
    May 2008
    New Zealand
    hitachi wire edm controller
    I forgot to mention that the Hitachi has a 6 series Fanuc controller. Any help would be really appreciated as I am at my wits end with this!
    Apr 2008
    Do you have the vertical lock button set on the controller?
    Jul 2008
    Dunno if it will help (and I'm doing this from memory so I hope that I'm correct when I say)....I'm a Mits user...but, UNLESS you've got a left or right cutter comp in effect (G41 or G42)...taper won't move.
    -Brent
