Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: oxygen gas for cutting
    Feb 2008
    Was wondering if anyone could tell me how many cuts or at what rate you would go though oxygen on a cnc table? Being used for Plasma Cutting!Thanks Dennis
    Aug 2007
    Romania
    I work in CNC oxygas cutting for 10 years but dont undersand your question.
    Feb 2008
    What is the rate of gas usage! How much gas will i use ! Will it break me !
    Aug 2007
    Romania
    First you must tell what material you want to cut (thickness and steel quality)and what torch.
    Because is a link betwen torch duse and thickness of material.
    An aproximate guess is 7 bars Oxygen and 3 bars propane gas. for 500 mm/min.
    Some pictures (or links) of the machine, gas tanks, parts to be cuts are welcome.
    Registered Weldtutor's Avatar
    Oct 2005
    Question Oxygen For Plasma
    Quote Originally Posted by Pure-Powder View Post
    Is the plasma cutter you plan to use designed for oxygen?
    Most smaller ones are for compressed air only.
    Feb 2008
    HYPERTHERM G3 1000, AND 1/8 MILD STEEL
    Feb 2008
    NOT REALLY SURE ITS STILL LAYING IN THE BOX ON THE FLOOR...
    Aug 2007
    Romania
    Now I understand. I think you can use the same presure from air, and reduce the presure until the quality of the cut is still good. But for 3 mm steel, the air is not bad for the quality of the cut. Why change the gas?
    Hypertherm recomand this.
    Flow rate / 400 scfh; 6.7 cfm (189 l/min) at 90 psi (6.2 bar)
    If in my country the oxygen tanks has 6.5 cubic meters = 6500 liter
    then in aprox. half hour the tank is empty.
    Aug 2007
    Romania
    I am very shure that my calculation are wrong
    Gec
    Gec is offline
    Oct 2007
    Croatia
    You can't use oxigen on that plasma cutter, only air or nitrogen.
    Oct 2005
    Here is a link to the machine's specifications & requirements. Air, not oxygen.
    http://www.airgas.com/browse/product...D&recIds=26499
    Feb 2008
    WAS WONDERING IF CUT QUALITY WOULD BE BETTER, BUT NO IF IT TAKES THAT MUCH OXYGEN.... WOULD COST A SMALL FORTUNE.... THINK I WILL JUST BUY A AIR DRYER
  • Page 1 of 2 12 LastLast
    1. Oxygen or N2 pressure for Co2 laser
      By oljeg in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-15-2007, 08:48 AM
    2. Oxygen Pierce solenoid Valve
      By roady89 in forum General Waterjet
      Last Post: 10-05-2007, 06:11 PM
    3. Alu Engine to run on water (Hydrogen + Oxygen)
      By ADucci in forum I.C. Engines
      Last Post: 07-01-2007, 06:24 PM
    4. I need help about cutting heads which apply to apparel pattern cutting machine
      By sheepgrass in forum Mechanical Calculations/Engineering Design
      Last Post: 05-12-2006, 02:09 PM
    5. C02 laser cutting and oxygen safety
      By owhite in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-01-2005, 09:30 AM
