Results 1 to 3 of 3
Thread: how do you control the plasma torch on/off
    Jun 2007
    romania
    exactly what setings in mach do u use.. i've been tring to triger the relay for about 3 days nothing happens.
    i understand the pin and port might be diffrent .
    May 2007
    Thailand
    Smile Turn on/ off plasma
    Hi Bekx,
    What pin did you test? It should be pin1 of DB25 pin to turn on or off plasma.
    Mongkol
    Jun 2007
    romania
    it is an issue with the driver board , it's using MAX CL setings and that interferes somehow with the pin 8 (that's trigering the relay) .
    with max cl disabled i can triger the relay but i loose the x-y movement..
    i think dubble can sort this out.
    on the other hand everythings works in kcam4 .. the relay and the table but it's more difficult to use, i got no sheetcam post processor for kcam, and i allready bought mach3 license...
    it's clear now DIY cnc needs to have headache pills included
    @mongkol tx m8 , i know what pin uses my controller .. it's the setings in mach3 i'm intrested, anyway found the setings but don't work with my controller setup..
  1. Plasma Torch Height Control System
    By kanankeban in forum General Waterjet
    Last Post: 03-13-2009, 03:55 AM
  2. Plasma Torch
    By Dembo in forum General Waterjet
    Last Post: 09-26-2008, 02:27 PM
  3. Idea for a $10 plasma torch height control- Thoughts?
    By sbalder in forum General Waterjet
    Last Post: 04-22-2008, 09:31 PM
  4. Plasma Torch Height Control System
    Last Post: 11-04-2004, 08:18 PM
