Results 1 to 10 of 10
Thread: Plasma Torch questions
    Feb 2007
    Question Plasma Torch questions
    I have a Hypertherm 1000 sitting on a Practical CNC with a torch height control. I have encountered a new problem and I am not sure what is causing the trouble. Once the program is started the THC measures the distance to steel and then the torch ignites and cuts but once the torch retracts to move to next position and does the touch off again it does not ignite.
    I have installed new consumables, made sure there is no air in filter line, checked the pressure coming in and going out.......made sure the ground was good. No wires appear to be loose anywhere.......Yet, it will not reignite after the first inital time.
    Anyone know what is going on, it has not done this before.
    Jan 2007
    CA
    check the toggle switch on the front make sure its set all the way up
    Feb 2007
    Check what toggle switch, on the controller box. There is no other that I can think of...I will check it tomorrow.
    Jan 2007
    CA
    there is a switch on the plasma unit that you can set to continuous cutting, interupted, beveled. make sure its set to continou cutting
    Feb 2007
    It took a long time to get back, sorry out of town. No it isn't the switch that is set correctly. Now it gives me a 10 second red light when the torch is activated, according to the hypertherm manual that is suppose to indicate stuck or jammed consumables. I have replaced all the consumables and none are sticking, but it still will not ignite. Once in a while it will ignite, but it never does when moving to the next position. I have just started going over it again today, due to being out of town. Any other ideas will be welcomed.
    Jan 2008
    I would suggest contacting Hypertherm tech service with your symptoms. It is free, and these guys are there waiting for your calls or emails....ready to help you determine the problem.
    HySupport
    Technical service
    technical.service@hypertherm.com
    800-643-9878 Tel - Toll Free in USA and Canada
    Jim Colt
    Feb 2007
    Thanks I just send off a message to them, appreciate the suggestion. I did try the local distributor...but they weren't much help.
    Jul 2006
    England
    If I remove the consumables, I always get error lights showing on my Hypertherm 1000
    I have to switch it off and on again to reset it.
    Andy
    Aug 2007
    Do you have any moisture probs in your air lines?
    Mike
    Feb 2007
    Hypertherm 1000
    I am trying it out today, I talked to the rep. from Hypertherm he suggested to back off the consumables 1/2 turn maybe it is to tight. He also gave me a list of lights to check on the board. The lights will help them to determine the condition. Hopefully with some luck we can nail this down.
    I have 4 filters on the lines to keep moisture out, and I am not finding any. So I ruled that one out.
    Thanks for the help and suggestions!!!!!
    1. Plasma Torch
      By Dembo in forum General Waterjet
      Last Post: 09-26-2008, 02:27 PM
    2. blower for plasma/torch cfm??
      By DanOSB in forum General Waterjet
      Last Post: 01-10-2006, 08:55 AM
    3. What model plasma torch to buy.
      By Apples in forum General Waterjet
      Last Post: 10-01-2005, 06:20 PM
    4. Plasma Torch and Z Axis
      By krazycnc in forum General Waterjet
      Last Post: 08-10-2005, 05:58 PM
    5. plasma torch triggering
      By anthony in forum SheetCam
      Last Post: 05-05-2005, 02:03 PM
