I'm cnc plasma newbie. Is there someone can thoughtfully solve this
problem for me? Is Hypertherm modern non-HF start units?
> Thank you so much for all advice, I'm just realized that how important
> grounding plasma machine is. I have never connected grounding rod
for
> my two plasma machines. I use to think that connecting input cable to
> my electric breaker is enough. Moreover, I've experienced with the
> COMPUTER resetting for no reason and my 3 axis board sut down
when
> I tried to operate my plasma machine (I've tried both of them) with
my
> cnc table. After that, I called to my plasma machine dealer for solution.
He
> told me about the cause of High Frequency of both machines and
bring
> me Hypertherm max600 to try out. Hyperther Max600 is worked well.
> My question is, if I connect proper grounding, May I use my two
plasma
> machines for cnc table or I have to buy Hypertherm Max600?.
Moreover, Does THC300 can operate to my following machine?
Please recommend Thank you
> First Machine is Panasonic Cut Star PS 50(with 3 steps Amp 25,40,63
> adjustable). The specification is between Panasonic Cut Star PS 33
and
> PS 60. The link is here http://www.tsmi.com.cn/English/cp9.htm
> Second Machine is local brand Siam Neoline Model Cut-52. The
> specification is here http://www.v1engineer.com/plasma2.html
LinkBack URL
About LinkBacks
