Hello,
I am having a problem with a Titan Messer MG cutting table with two hypertherm HT2000 plasmas, it has the control height unit from interlogic. The problem is that the cnc control send the start signal to the plasma and the gas preflow start but the arc do not come untill the "auto height" switch is turned off momentarily, after that the program runs perfect makeing the height control over the plate, when the cut finished and a new one will start the "auto height" switch has to be switched off and on again.
Any ideas?
Sir,
Why not contact MG to get their help. I'm sure they would want their machines to work OK.
Regards,
Jack C.
