Page 1 of 4 1234 LastLast
Results 1 to 12 of 42
Thread: Water Table Rust Questions...
    Feb 2007
    Hello All, I been here a couple of months but am new to post. I have just finished building a water table for our new 4X8 Torchmate 3. We have been cutting for a couple of weeks now and most everything is going very well except for a few concerns.
    1. during operation of the torch cutting the flame is throwing water back up onto my machine and all around. Most guys I've asked say they set the water level at just right under the material thier cuttting. Is this correct or should it be a little lower? What is the recommended height of water to material?
    2. and -- Is there any chemical or process I can add to my water table to get rid of the rust the water is causing not only on the slag left by the cut but also (more importantly) to the support slats in the water? The table itself is coated in rubber --but the slats are not. I am having a lot of rust build up on the support slats of the table.
    Any help would be greatly appreciated.
    hot rod kid
    Jul 2004
    Don't worry about the rust, as you will need to replace the slats long before they will rust out. The interesting thing about rust is once it totaly covers a piece of metal it acts like a coating, and slows down it's own progression. Most coatings that you could put on the slats would give off fumes as you cut into them.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Nov 2006
    Contact the following company about a water table additive.
    Koal Industries
    Elk Grove Village IL
    847 956 9720
    Product would be Koal Quench 617.2
    Feb 2007
    Rust...
    Never thought about that. Before the time they would rust away they'd need replacing anyway. The side supports that hold the slats in place are stainless so there is no worry there. I was going to use the old method of arm and hammer wash and a battery charger connected to two stainless rods in the tank to just keep the water cleaner --but on second thought and a little research I am afraid the current will affect or harm the motors and torch height control on my machine! Don't want to do that---- they don't give that stuff away.
    Thanks for the input.
    hot rod kid
    Feb 2007
    Thank You --I'll check into this today.
    Jan 2007
    The water splashing back shouldn't be of any concern unless it were possible to soak the motor or height control connections enough to short out the electronics. On the Torchmate 4 we've never had any issues with it.
    We also recommend the Koal Industries plasma quench. Although we haven't had any issues with tables that don't have any additives in the water. The slats will rust, as will the material if you let it sit in the water.
    While cutting we usually recommend having the water level at the top of your slats or just touching the bottom of the material, this is the most efficient at collecting smoke and dust as well as an added bonus of keeping the material cool.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Feb 2007
    Hello Mike, I think I'm going to try the Koal Industries plasma quench --I think it'll solve my problems with that. The water splashing up is not terrible but does make a little bit of a mess. The water does not get on the connections or motors but does splash back up on the T gantry slide rail some.
    I'd like to say --- You guys have been GREAT as far as helping me out with getting the TM3 up and going! There has been no lack of support from your end at all --and I really appreciate that. Not to mention the machine itself is WONDERFUL! I researched many machines on the market and scanned cnc zone a lot before buying. And at this point I couldn't be happier.
    I'll post some photos of my table before long. We made 2 tables in one. The outer table is made in the shape of a square U. The inner table is the water table which I can unbolt and roll out of the U table for cleaning away from the machine itself. Water table is sealed on the inside with a truck bed undercoating spray on rubber. I'll have photos later on.
    Thanks again Mike
    hot rod kid
    Aug 2004
    plasma quench
    Does any one know of any other product that does the same as plasma quench.
    I contacted them back in May and placed an order and paid etc. it is now July and no plasma quench with plenty of excuses.
    Has any one else had good or bad experiences with this company?
    thanks
    Clint
    Oct 2007
    Plasma quench- make your own
    Someone a while back posted the mixture for making your own plasma quench...May want to do a search? Not sure how well it worked.
    Mick
    Sep 2006
    Kentucky, USA
    I'll throw in my 2 cents for Plasma Quench. I've been using it for almost a year now, and don't have any problems with rust or odor. Great product. According to the MSDS sheet http://http://www2.hazard.com/msds/f2/bqr/bqrcv.html , Plasma Quench's major component is Sodium Nitrate.
    Dec 2007
    Bad experience with Koal , they charged my credit card ($300+) and never shipped.....don't order unless they ship collect.
    I tried to contact them many times, and was told that it would take time to process the order. I think they are in finacial trouble.
    buyer beware!
    Can't Fix Stupid
    Aug 2004
    plasma quench
    I still have not received my Plasma Quench over two months of waiting.
    They have moved to the bonnie lane and they have several complaints on their two previous addresses.
    If you have paid for Plasma Quench and not received it. Then here is the information to
    The Attorney generals office, phone number is 312-814-3000 ask for the consumer fraud division. They will be happy to help.
    47MLB
  • Page 1 of 4 1234 LastLast
    1. need water table info
      By massajamesb in forum General Waterjet
      Last Post: 08-25-2007, 01:23 PM
    2. Plasma+water table on casters?
      By DeviousMW in forum General Waterjet
      Last Post: 05-05-2007, 12:51 AM
    3. Water transfer techniques for water table?
      By Knut in forum General Waterjet
      Last Post: 02-02-2007, 10:52 AM
    4. plasma water pan rust inhibitor
      By 40fordcoupe in forum General Waterjet
      Last Post: 07-01-2006, 07:01 PM
