Results 1 to 5 of 5
Thread: spring loaded rack and pinion
    May 2005
    I was running a ridgid setup for awhile but i really didnt care for it. and every one says how great the spring loaded racks work . so here is the one im working on it has 2 springs and 20 series heavy duty thomson accuglide rail
    what do you guys think
    John
    Attached Thumbnails Attached Thumbnails spring loaded rack and pinion-tomsplate_011.jpg
    Registered PlasmaGuy's Avatar
    Aug 2004
    John,
    I like your design but have you thought about inverting the rack so no slag or other trash can rest there?
    My table is like yours and the rack collects grit, etc. My next one will have the rack teethpointing down not up.
    Good luck,
    Tom
    May 2005
    man that is a great idea
    May 2003
    Illinois
    Dgalaxy,
    If you would like to see an approach we have used for some time, email me and I can attach .DXF file and pictures for your consideration. jccinc-at-owc-dot-net
    Regards,
    Jack C.
    Jul 2006
    us
    I like the spring design. Although I bought a ready to go table. My Dynatorch table uses small Bimba air cylinders to hold the gear on the rack, and yes My racks are facing down as to not have slag clog up the gears. I like that when the air is turned off you can slide the rack by hand on both the X and Y axis.
    Ed-Ryno
    www.rynomobility.com
  • Posting Permissions
