Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: custom plasma cutting machine ?
    Oct 2006
    I have a small machine shop and I have a job that requires me to cut 3/8" off of the flanges of 3" channel iron. I am milling them now and it is taking longer than I would like.
    I was thinking about making a conveyor type machine that would run continuosly and pass the channels past two plasma cutters so that it would cut both flanges at the same time.
    I am just wondering how fast it would cut and how much maintence it would require to keep it running continuously like this? I have to cut 1,200 pieces per month and they are 3' long.
    Any help on this would be apprecciated.
    Registered massajamesb's Avatar
    Mar 2006
    You could also design the machine to rotate the channel 180 degrees, as to save money on an extra plasma.
    Will the plasma's 5 degree bevel be an issue on the flanges?
    Depending on the amperage and duty cycle of your plasma, that will determine your efficiency, I would think. You would have to spend a lot of money to buy two machines with the duty cycle and sufficient power to cut 3/8 all day long.
    I am guessing you're looking at 120 feet of material a day. A larger machine (minimum 50-60 amps) should cut anywhere from 35"/min to 50"/min (possibly more +- 10%) so 1440 inches a day / 36" min = 40 minutes of cutting time per day. This is if you are running 2 plasma machines simultaneously. With one plasma, double that time.
    In other words, theoretically, you are looking at cutting one 3' piece per minute if you are using dual plasmas. Total cutting time will be in the 1 hour range per day, if you run 7 days a week with dual plasma.
    Figure in downtime for consumable replacement, stock loading and unloading, cleanup, etc. Don't know if you load these channels in full sticks, 3' pieces, use a forklift, etc. That is another matter.
    Consumable efficiency varies with each machine, but the best IMO is Hypertherm. Electrodes last longer but cost a little more than the competition.
    I might be completely wrong about all this, if I am I apologize. I know larger production or industrial plasma's can cut faster (such as High Def plasma) but you will break the bank on one that big.
    It all boils down to what my racer buddies all tell me. " Speed costs money. How fast do you want to go?"
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Oct 2006
    Thank You very much for the reply.
    The channel flange is only 1/4" thick after I mill them.
    Would it be possible to mount the plasma torch at a 5 degree angle to compensate for the bevel?
    Now, I am milling these and I am getting 10 pieces per hour. The cutters are lasting for about 100 pieces before they need replacing. The pieces are already cut to length when I get them. I realize that consumables life will very but do you have a ball park figure? I was just wondering if might be 10 pieces or 100 pieces? I have no idea.
    Mar 2006
    You bring up an excellent point about changing the torch angle. That might be very well possible, as most people don't do it because they are going to be cutting in different directions, whereas you will only be cutting in one direction. I would definately give it some thought.
    As far as consumable life, it again depends on your machine, how clean your air is, how clean the steel is, and the cutting distance.
    Now, are you milling them to be 1/4" thick, or ?? I don't quite understand.
    1/4 thick steel will not have a real noticeable bevel. Anything thicker will.
    I would bet if you had a dessicant air dryer inline with the plasma, cutting at a constant 40 amps, using a Hypertherm 1250, you could probably get (at a guess) 15-20 pieces, both sides, possibly. I have never cut 3/8 constantly, in a straight line, like you are asking.
    -RedGreen show.
    Oct 2006
    Just to clear this up, the channel flange is tapered but it is 1/4 thick at the place where the plasma would make the cut.
    Mar 2006
    Ahhh. Gotcha. Bevel should not be a real problem, then.
    Do you have a plasma you are keeping in mind?
    Are you open for suggestions, I should say?
    Are you for sure you are going to run two plasmas at once?
    -RedGreen show.
    Oct 2006
    I am very open to suggestions. I will definitely use just one plasma at first to see how things go.
    I was looking at a Miller 625 but I was just looking.
    Mar 2006
    That is a great plasma, no doubt, but it will not have the duty cycle you need nor will the consumables last very long while cutting 3/8. I suggest you look into Hypertherm, minimum 1000 model. Thermal dynamics has a PAK85 unit that aint bad and is a tad cheaper. For Miller, I would look at the 2050.
    A 30 amp machine will cut 3/8 just fine, but it will not have the duty cycle to run continuously. Beyond that the consumables will not last long enough as some that are designed for a larger machine.
    A 50 amp machine should be the minimum you are looking for, IMO.
    -RedGreen show.
    May 2003
    Illinois
    Sir,
    Now this might sound kinda silly, but couldn't you saw them off?? Maybe there
    is some other aspect that eliminates sawing?
    Jack C.
    Oct 2006
    Jack,
    Yes you could saw them off but what kind of saw would cut at 35" per minute on 1/4" steel?
    Aug 2004
    jpcuttergrinder....if it's only taking you 6 minutes to do each piece....then you may have the most optimum method, short of using a shear press...
    Registered Redline's Avatar
    Oct 2004
    This may sound stupid but you could make a single axis CNC plasma cutter to do that job.It would be cheap and easy.
  • Page 1 of 2 12 LastLast
