Results 1 to 6 of 6
Thread: 2 tpi lead screw? What motors?
    Registered Redline's Avatar
    Oct 2004
    I have a 6 foot 2 tpi w/4starts lead screw what would be the best size stepper motors to use?I would like to use a xylotex bipolar controller
    @24 volts with 286 oz/in motors.I have a FET-3 with 150 oz/in @12 volts at the moment but i do not think it will cut the mustard . What do you guys think? I would like to get it to run between 20ipm and 100ipm.
    Thanks Jim
    Mar 2003
    Shelby Twp, MI....USA
    What diameter is the screw, and how much weight are you moving?
    Registered strat's Avatar
    Oct 2003
    with the 1/2 -10 5 start i'm using a xylo and 276 oz-in motors for fun i can move at about 350 ipm so shouldn't be a prob for the biggest part i don't really go over 150 ipm but the speed is there and possable
    Oct 2004
    3/8-8 2tpi 4 starts.
    Mar 2003
    You didn't say how much weight you were moving, but they should work OK. If your not moving a lot of weight, they should give you a LOT of speed.
    Oct 2004
    The X-axis will be pushing about 30 lbs.Also it is for a plasma cnc so that is all the load that will be on that axis.
  • Posting Permissions
