Michael,
Hypertherm 1250 should handle the plate.
One item to consider for adding this to your table is 1) keep the hi voltage from the low voltage for drive wires, sensors, and 2) you will need a air compressor. 60 gal minimum.
Both the cutter, and air compressor will probably require higher voltage than simple outlet power, so additional concerns about voltages available to the table are also to be considered.
The final concern, will be the smoke, and slag from the table. Additionaly, metal slats should be used to place the metal on, instead of the support for a router.
HTH Bill
LinkBack URL
About LinkBacks
