Results 1 to 5 of 5
Thread: Best Plasma for thin SS sheets
    May 2007
    Bahrain
    Question Best Plasma for thin SS sheets
    Dear Friends,
    Can anyone suggest me best plasma source for cutting thin SS, Aluminum while capable enough to cut little thick metals occasionally.
    I intend to use this plasma with Chinese built table.
    Jan 2008
    The best plasma for cutting a wide range of materials are the Hypertherm HPRxd (high definition) plasma cutting systems. They are available in 130, 260, 400 and 800 amp versions. These are all 100% duty cycle mechanized high definition class plasma systems.
    Jim Colt
    Quote Originally Posted by mohideenakm View Post
    Dear Friends,
    May 2007
    Bahrain
    Quote Originally Posted by jimcolt View Post
    Jim Colt
    Thanks for your reply JIM.
    what about PowerMax 45 compare to HPRxD?
    Jan 2008
    You asked for the "Best" plasma system! The Powermax45 is an air plasma system that cuts thin stainless well....but, compared to our industrial high definition systems it is slower and the cut quality is not comparable.
    If you want the best air plasma (low price, lower duty cycle) then I would recommend the Powermax45, 65, 85 or 105 system....depending on the maximum thickness you also need to cut.
    Jim Colt
    May 2007
    Bahrain
    Thanks Jim for your advice,
    I would like to go with Powermax 45 or 65, later I will upgrade.
    what is the buying option for Middle East (Bahrain)?
    Jim Colt
    1. How do you Lift BIG heavy sheets on to your plasma?
      By Momentz in forum Plasma, EDM and other similar machine Project Log
      Last Post: 02-16-2012, 05:41 PM
    2. Problem- Plasma- Multiple layered AL thin sheet cutting?
      By diyengineer in forum General Waterjet
      Last Post: 08-21-2011, 07:06 PM
    3. Colored phenolic? Thin corian sheets?
      By stevespo in forum Want To Buy...Need help!
      Last Post: 05-22-2010, 05:38 PM
    4. Need Help!- X3 SET UP SHEETS
      By CNC_BOB in forum Mastercam
      Last Post: 03-16-2010, 10:10 PM
    5. Build Thread- set up sheets
      By 1234567 in forum BobCad-Cam
      Last Post: 10-27-2009, 02:38 PM
