Results 1 to 3 of 3
Thread: laminated shmstock on waterjet
    Jun 2004
    i have a waterjetr question , will waterjet peirce and cut laminated shimstock without delaminating it , the material is aluminum , brass and steel lamintaed shimstock with laminations from .001 -,005 in several layers.
    thanks
    Jun 2004
    forgot to add that the overall thickness is from .050 - .375 overall thickness
    Jul 2009
    NL
    I have let a company try cutting hpl. They could not start in the middle, the pressure went sideways inside the material. Starting from the side was possible but that leaves out a whole lot of things to be made...
    Sven
    http://www.puresven.com/?q=building-cnc-router
  1. Need Help!- Cutting thin laminated CF
    By edwinshap in forum Composites, Exotic Metals etc
    Last Post: 01-04-2012, 10:52 PM
  2. Need Help!- sellecting bit to cut laminated paper
    By Argetsinger in forum CNC Tooling
    Last Post: 08-22-2010, 10:11 PM
  3. Laminated Beam
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 10-23-2006, 10:43 PM
  4. Laminated verneer
    By p38nut in forum WoodWorking
    Last Post: 12-04-2005, 02:41 PM
  5. square laminated or toroid transformer?
    By freak_brain in forum General Electronics Discussion
    Last Post: 07-09-2005, 08:12 PM
