Results 1 to 3 of 3
Thread: Ideal table height and slats
    Dec 2005
    I'm building a plasma table and now I'm up to building the legs-supporting frame. My thought is the height where the material sits will be 32". as far as the slats go I see interlocking checker boards and simple curved parallel designs. what are the pros and cons to each design
    3250 plasma table build
    Feb 2011
    Good question.
    Your link is incorrect. (One too many http://) Try this one:
    http://www.cnczone.com/forums/plasma...ble_build.html
    Registered Teknition's Avatar
    Dec 2005
    It all depends on how tall you are. In my opinion, the perfect table height is so that you can reach the centre of the table from both sides with your feet on the floor. It would really suck to have to keep climbing up on the table to get those parts in the middle. I think a interlocking checkerboard would be a bit overkill. You are going to use twice as much metal that way. If you have 3 anchor points for your slats, one in the centre and one on both ends, and curve your slats then all you will need is slats running on one axis. For an example, you can se how my slats are layed out here
    PrecisionPlasma/CandCNC 5X10 table build
    Brad
  1. Table Height?
    By Jeep07 in forum General Waterjet
    Last Post: 11-11-2010, 01:32 PM
  2. Need Help!- preventing rust on water table slats?
    By wolfe sculpture in forum General Waterjet
    Last Post: 02-02-2010, 10:38 PM
  3. water table depth and height of slats?
    By bseibenick in forum General Waterjet
    Last Post: 12-08-2008, 12:00 PM
  4. Ideal table height for a mill
    By ranchak in forum General Metal Working Machines
    Last Post: 11-20-2007, 02:19 PM
  5. Torchmate, 4x4 table slats
    By balto in forum Torchmate
    Last Post: 08-10-2007, 10:45 AM
