Results 1 to 2 of 2
Thread: repair a broken ground cable
    Feb 2012
    I need to fix a Sodick AQ750 wire edm ASAP.
    The two cables that send power to the lower head were severed to bits when I dropped an 800lb block into the tank.
    We're ordering replacements tomorrow, but is there any issue with jerry-rigging a temporary cable out of something at the shop?
    I'm no engineer, but the only problem I can think of would be the high frequency of the electricity could cause capacitance issues...
    Dec 2006
    If the cables are cut clean there isnt much you can do. You can try and make some older heavy guage copper discharge wires but it will take several and for the money that it takes to build them it isnt worth it.
  1. Remove Pins in Connector - Repair broken wires
    By ontariocnc in forum Maintenance DIY Discussion
    Last Post: 05-04-2012, 01:35 AM
  2. G540 Sheilded cable ground
    By LazyMan in forum Gecko Drives
    Last Post: 07-27-2011, 07:26 PM
  3. Frame ground vs. Electrical ground.
    By polaraligned in forum Granite Devices
    Last Post: 11-24-2008, 05:21 PM
  4. Need Help!- To Ground or not to Ground That is the question!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 04:10 PM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum General Electronics Discussion
    Last Post: 06-07-2005, 06:21 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
