Results 1 to 2 of 2
Thread: EDM wire cutter g-code?
    May 2010
    UK
    Hi all,
    I have been asked at work to learn to program our joemars EDM wire cutter, I have a good Knowledge of Autocad and Solidworks and also understand how cnc machines work, but its been a very long time since i last played around with g-code.
    I have a small file created in note pad, which generates correctly in a piece of software called CNC simulator, but im not sure about the corect modal codes to use and the correct way to apply the file to the wire cutter.
    Any advice on creating these sort of files will be greatly apreciated.
    Oh and if anyone knows of a good code generator for EDM machines please let me know.
    This is also posted in the mentors section, sorry i didnt know how to remove it!
    May 2010
    UK
    Ok,
    So here is the code at the moment.
    (PROGRAM START - SET NOTCH CENTER)
    S1D1
    G21 G90 G64
    G92 Y0.0 X0.0
    G00 Y-1.0 X0.0
    G00 Y-1.0 X-0.625
    G00 Y-0.1 X-0.625
    G01 Y2.0 X-0.625 F1
    G01 Y0.65 X-1.975
    G01 Y0.30 X-1.975
    G01 Y0.30 X-1.625
    G01 Y-0.1 X-1.625
    G00 Y-1.0 X-1.625
    G00 Y-1.0 X0.625
    G00 Y-0.1 X0.625
    G01 Y2.0 X0.625
    G01 Y0.65 X1.975
    G01 Y0.30 X1.975
    G01 Y0.30 X1.625
    G01 Y-0.1 X1.625
    G00 Y-1.0 XI.625
    G00 Y-1.0 X0.0
    G00 Y0.0 X0.0
    M30
    Does this look ok?
  1. EDM wire cutter g-code?
    By Plecc in forum Mentors & Apprentice Locator
    Last Post: 03-24-2012, 05:13 PM
  2. Need Help!- What 4 axis CNC hot wire cutter to buy?
    By Snowy in forum CNC Wire Foam Cutter Machines
    Last Post: 12-07-2011, 07:18 PM
  3. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  4. Hot-Wire Cutter Software
    By Alonson in forum Foam Cutting Software
    Last Post: 04-14-2008, 01:52 PM
  5. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-16-2006, 08:57 PM
