I Lean
From looking at how far your Z and torch mounts out away from your gantry I would say that is where all your problems are. When you mount something that far out it has a lot of leverage on your gantry and when you have a fast change in direction it will cause the gantry to flex a lot. If you take a look at my post on my machine and look at the pics with the x axis you will see how close I have the z axis. If you rework it closer you wouldn't need to modify your gantry.
LinkBack URL
About LinkBacks
