You might find your breakage limit is set to 1 set it higher to make it recover. with the skip function used too it will retry the amount you set it to if it breaks a final time it will rapid around the profile and move to the next assuming if you're using the micro-joint and M01 functions
HTH
LinkBack URL
About LinkBacks
