Results 1 to 6 of 6
Thread: vibration from rack and pinion
    Aug 2008
    UK
    Hi.
    I'm getting noticable vibration from the rack and pinion. Mod 1 rack 15mm square. engaging with 23 t mod 1 pinion. the pinion is sprung loaded into the rack.
    Any one with any tips or tricks to quieten this down.
    Jul 2005
    Direct drive motors (to the pinion) or belt reduction?
    Aug 2008
    UK
    2.75 reduction, I think a possible cause is poor quality rack?
    Jul 2005
    Normally a lot of the vibration comes from the motors and mechanical links. Turn the motors off and slide the axis by hand and feel for vibration Bad pinion mesh should show up as you move.
    If you have a gantry wider than 36" and only driving one side then consider the possibility of binding from racking.
    unhook motors from belts and jog them at different speeds. If you are using microstepping drives the rotation should be nice and smooth. If it grinds or vibrates the motors then either the drivers are a POS or your step polarity in MACH is wrong.
    If you have the velocity set too high for your driver/motor/belt reduction then you could be losing steps that will cause motors to run rough.
    If you are using MACh then Windows, background services can bit you and cause a ragged pulse stream (or one that has periodic bumps you can hear.
    If you have the correct pitch (distance between teeth AND the pressure angle matches between the pinion gear and the rack, it should run pretty smooth if the driving force is turning smooth.
    TOMcaudle
    www.candcnc.com
    Sep 2005
    Hi Adscnc,
    unrelated to this topic but you should have a private message from me asking about that severe bevel problem you posted about a while back. I was wondering if you found out what was causing it.
    Cheers,
    Keith.
    Aug 2008
    UK
    torch had been involved in a collision so was a little bent, replaced it and was all okay,
    1. Need Help!- dual pinion rack and pinion anti backlash
      By johngalt47 in forum DIY CNC Router Table Machines
      Last Post: 06-11-2011, 11:04 PM
    2. Rack and Pinion- rack tensioned to pinion?
      By Rees Guitars in forum Linear and Rotary Motion
      Last Post: 05-09-2011, 01:05 PM
    3. Need Help!- Gantry vibration with rack and pinion
      By powerfade in forum DIY CNC Router Table Machines
      Last Post: 12-26-2009, 11:38 PM
    4. rack and rack & pinion with off the self planetary gearbox
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 12-06-2009, 09:54 AM
    5. calculatiing pinion size for rack and pinion setup
      By Apples in forum DIY CNC Router Table Machines
      Last Post: 05-18-2004, 10:36 PM
