Results 1 to 5 of 5
Thread: Cutmaster A60 power supply question
    Jan 2012
    I have a Cutmaster A60 and I just got the power cable and plug put on it since it comes without a plug. I had a 50amp 4 prong plug installed in my garage. Then on the plasma cutter I put on a 4 wire range cord (6 gauge wire). Its set up with black to L1, white to L2, and the red to L3. The jumper from L2 to L3 has been removed and the jumper from L1 to L4 is still in place. I'm no electrician, so I wanted to double check that I did this right. Appreciate any input.
    Jan 2008
    Your A60 operators manual has details....and the Thermal Dynamics tech service department are very helpful as well!
    Jim Colt Hypertherm
    Quote Originally Posted by cinderella View Post
    Jan 2012
    That's where I found the instructions. I believe it is 3 phase right now and I thought residential homes can't handle that. Don't wanna cause sparks anywhere other than on my sheet metal.
    Jan 2012
    Btw...you, Jim, are everywhere online supporting CNC even if its not your product. Pretty cool!
    Jan 2008
    I just like melting things! Well, in a controlled manner using a plasma torch!
    Jim
    1. Power supply question
      By TarHeelTom in forum General Electronics Discussion
      Last Post: 03-13-2011, 05:22 AM
    2. Yet another power supply question
      By TMaster in forum Gecko Drives
      Last Post: 05-27-2010, 11:28 PM
    3. Power supply question
      By Thomasdj in forum General Electronics Discussion
      Last Post: 02-13-2009, 02:24 PM
    4. Power Supply Question
      By jjwl89 in forum General Electronics Discussion
      Last Post: 07-21-2004, 10:51 AM
    5. Power Supply question
      By Alan T. in forum Xylotex
      Last Post: 05-04-2004, 09:59 AM
